Results 1 to 5 of 5
Thread: HELP, ASAP... SHOUlD i buy these 17's????
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Exclamation HELP, ASAP... SHOUlD i buy these 17's????
    Hey, I am now faced with a problem... I kinda didn't want to go with 17" rims, for the performance factor, and cuz my car isnt lowered, and i think they might look kinda bad.
    And I got a flyer via email from this local rim shop I was talkin to about rims... and they had 16" rims for like 70/80$ canadian ... But I called and they are all out. All that I can get now is 17's, but they are still cheap as hell.. Like $90 a rim.
    But I don't know if I should settle for 17's and maybe end up selling them down the road.
    Please help me decide.. how will 17's look at stock height??? and will i notice a difference performance wise?
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    I'm assuming those rims are heavier than stock which means they will slow you down some. They don't look horrible, but without a lowering, your car'll look somewhat like a 4x4. Also keep in mind that tires for bigger rims are more expensive than smaller rims, if that matters to you (though the prices are pretty darn close).
    Alex
    2.0Si User zero.counter's Avatar
    2006 Nissan 350z
    Does school count?
    Re: HELP, ASAP... SHOUlD i buy these 17's????
    Everything that 86AccordLxi said is true to the core. Cost should not be the deciding factor in customization as you will pay in the long run. You should investigate in a camber correction kit if you are going 17 because replacing those size tires won't be cheapo depot if you don't correct. The larger size will also show on speedometer by being a little faster that the speedometer shows, maybe a couple of MPH. The heaviness can sometimes affect mileage which hits the pocketbook. And finally, the offset. You dont want the rims sticking out like a bulldog stance or running into a clearance issue do you?
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    Calgary, AB, Canada
    Ya, I decided to wait on it... The guy may be able to get more 16" rims for the amazing price of about 70/80$ a rim.. and I will definately be better off like that, and tires will be cheaper too.
    SEi User 88 Accord DX's Avatar
    Jul 2002
    '95 del Sol VTEC
    San Angelo, Texas
    IMO the jump from 16"-17" is not that much different. its the jump from 17"-18" thats a major change. id go with the 17's but thats just me.
    -T.C.
    Originally posted by HostileJava
    are you making fun of me because I think coroncho80 is hot?
  1. ASAP!!!! Throttle body/choke diaphragm Question!! ASAP!!!!
    By zack_attack2010 in forum 3geez Accords
    Last Post: 06-18-2009, 04:26 PM
  2. Need help asap!
    By tuner4life in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-28-2003, 04:25 PM
  3. Need Help ASAP HeLP!
    By lanman024 in forum 3geez Accords
    Last Post: 09-21-2003, 05:46 PM
  4. WTB Asap: 89 EFI ECU
    By 89accordhb in forum Trading Post
    Last Post: 08-06-2003, 12:10 PM
  5. help!!!!!!asap!!!sos!!
    By gameoner in forum Interior & Exterior Care
    Last Post: 07-16-2003, 04:09 PM
