Results 1 to 11 of 11
Thread: Code 2 i AM AT A LOSS
    1988starter
    Guest
    Well I got code 2 about a month ago and I replaced both O2 sensors now I am getting it again any ideas what might be setting it off guys.
    Idaho
    Does your car get shitty gas mileage or run shitty. If not I wouldn't worry about it.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    switch the plugs (green to white white to green)
    '88 LX-i Coupe --- LS/Vtec
    1988starter
    Guest
    Allready did that when I got the header and if I go back it runs like ass
    try putting a ground wire from the body of the sensor to the metal in the engine bay, see if the code goes away
    Eric
    Idaho
    I accidentally got the two o2 sensors switched, that might do it.
    1988starter
    Guest
    Ok I will give it a try but why
    Idaho
    Any luck? How does your car run?
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    have you tested the sensors?,....wiring,connectors?
    just because the ECU is throwing a code,...it may not actually be the sensor itself,...but a part of that particular circuit
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    maybe it's your timing starter I know what could settle this problem....... buy my motor and I'll get my swap done Or do a A20A1 and swap a fi motor to carbed!!!! :super:
    1988starter
    Guest
    Funny but the only reason yours purrs is because I set youir timing ha ha but any way i fixed it my ajustiable pressure regulator was on the frits so I put the stock one back on and I will try to fix the other.
  1. Loss of headlights
    By roofusgooner in forum 3geez Accords
    Last Post: 02-16-2008, 05:28 AM
  2. Power Loss
    By MattsAccord in forum 3geez Accords
    Last Post: 01-27-2005, 01:31 AM
  3. loss of power sometimes
    By Slamed89Accord in forum 3geez Accords
    Last Post: 02-19-2003, 08:10 PM
  4. performance loss! help!
    By CASH24 in forum Performance
    Last Post: 09-05-2002, 08:20 PM
  5. A/C hp loss
    By SteveDX89 in forum 3geez Accords
    Last Post: 08-15-2002, 08:14 PM
