Results 1 to 5 of 5
Thread: drivers side fan turns on after i turn the key
    Feb 2003
    1989 Honda Accord LxI
    Montrose, Colorado
    Well my fan turns on if i put the car into almost on, or if i turn off the car after letting it run for 10 seconds. It always comes on after i remove the key. I know it should not do this, and is there anything i can do to fix this? I just bought a voltage reader, so i can test this stuff.
    Feb 2003
    Montrose, Colorado
    tell me damnit
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    might be a fault in the control module....do a search, this has been talked about before
    Could be the module, wiring, or fan temp switch "b". It's located on the thermostat housing, between the ECT sensor and the bleed screw (green plug). That's the switch that start's the timing sequence. Unplug that sensor and see if your fan starts when you turn the key off.
    Steve
    Justin86's Avatar
    Medford, Oregon
    Well shit at least your fan works. I can't figure out how to get mine going.
  1. Drivers Side Leak
    By import racer in forum Classic Honda Community Chat
    Last Post: 03-23-2011, 04:41 PM
  2. Stalling turns off power to turn signals!?
    By DarkRedAccord in forum 3geez Accords
    Last Post: 10-05-2007, 06:19 AM
  3. drivers side window
    By dnk1999 in forum 3geez Accords
    Last Post: 09-18-2006, 06:27 PM
  4. drivers side mirror
    By Ace in forum Classic Honda Community Chat
    Last Post: 05-18-2005, 10:37 AM
  5. Replies: 0
    Last Post: 09-12-2003, 03:57 PM
