Results 1 to 6 of 6
Thread: Installing Cold Air Intake, please help..
    Do I need to take the bumper off? Or do I just need to take off that fender lining stuff?
    How do I go about this?
    Thanks
    1988 Accord LXI: Catco Hi-flo cat, 2.25" Stainless piping, stainless n1-style muffler, SR intake, NGK plugs and wires.
    SEi User cdscowboy's Avatar
    Nov 2002
    90 Nissan 240sx coupe
    Corvallis, OR
    You'll probably have to make the hole that goes down into your bumper slightly larger to fit the piping from your CAI through it. You will have to take of the front bumper if you want to put the filter on the end of the piping, which I'm pretty sure you do There's 3 screws in each wheel well that need to come out. There's a bolt in each of the (optional) fog light spaces. There's 12(I think it's 12...) bolts to take out on the top of the bumper...two (on each side) are under your sidemarker, so you'll have to take those out as well. The other 8 are in plain sight if the hood is up. And lastly, there should be two bolts on the bottom of the bumper. Pretty easy to find...essentially right in front of the radiator...very easy to get to...you'll see them. Hope that helps!
    You should take a look at 1988starter's "A how-to sort of....." post, that should help.
    Good luck!!! I'm getting mine later this week
    1988starter
    Guest
    I just took the dust shield off from the wheel well and under the bumper look in the peformance section for my almost a how to it will have a pict.
    Two holes on intake??
    Okay, one of the holes is going to a tube that is connected to the top of the valve cover.. what does the smaller little hole connect to?
    Justin86's Avatar
    Medford, Oregon
    Ummm could you be more descriptive. The hose on the valve cover is the valve cover breather. It hooks up to the air intake to get fresh air.
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    that one doesn't go anywere. Here's what i'd do though. Cover up both of those holes and get another breather for your valve cover. (i had the same thing)
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
  1. CEL after installing intake
    By shadowvox6 in forum Performance
    Last Post: 06-04-2010, 05:36 PM
  2. installing cold air intake?
    By jamesh23 in forum Performance
    Last Post: 12-31-2008, 03:37 PM
  3. installing b16 intake manifold on a20
    By othick in forum Performance
    Last Post: 01-28-2004, 11:26 PM
  4. help with installing intake
    By 89AccordLvr in forum 3geez Accords
    Last Post: 02-26-2003, 10:49 PM
  5. Vacuum lines and installing a cold air intake
    By Jims 86LXI HB in forum 3geez Accords
    Last Post: 06-13-2002, 02:53 PM
