Well, my oil pan has no leak from the gasket. Only problem: the drain plug has been stripped. From what I know, it was stripped before, then it was tapped, and then its stripped totally. I think its about 1/2 inch, because I would buy the 1/2 rubber drain plug, and it fits in there perfectly. My question now is : Can I do anything else to this drain plug? I don't like the idea of using this rubber plug( its unsafe in my opinion). Can I buy a self tapping screw before than 1/2 inch? As well as, is it POSSIBLE to remove the oil pan? I know you have to remove the pipes, that should easy. Is that all to remove that's an obstacle in taking out the pan? Any suggestion would be appreicated.
Legend9![]()
