Results 1 to 8 of 8
Thread: Jb Weld and our heads...
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    Ok, so we have a weak head on our car. One of my friends was saying that he used to have problems with head gaskets in one of his other vehicles so he got some jb weld, cleaned up the head got it surfaced and put the weld stuff on both sides of the gasket, torqued the bolts down and let it setup for a day. He said that you'll never have a head gasket problem again, but if something else fries on the engine just getcha another one. So i thought to my self. If it strengthens the head on that harley, and a civic (the two vehicles he did that to) then why can't it strengthen our head so that we can at more pressure from say a turbo. of course you'd still have to get all the other stuff, but would this help the problem with only being able to push 8-9 psi? Just a thought.
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Sure it would strengthen it....but theres a reason its call jb WELD. Once you put that shit on your head, good luck getting it off again if you need to. That stuff is like metal epoxy. Once its on, it aint coming off. Get yourself a custom metal gasket if you're planning on running higher compression. That way you wont have to replace your whole motor if you need your head or anything else underneath it fixed.
    Nothin' 2 Old Racing
    Knoxville, TN
    can't you get to your pistons and what not from your oil pan? Yah that's what my friend said. He said "you'll break the head before you get that it off" It would just seem to me that it would help in both high end revs and compression.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    yeah, you can get to the pistons from the oil pan, but its a pain in the ass. JB Weld seems like the getto way to get higher compression. Get a metal head gasket and better head bolts and you'll accomplish the same thing, but you'll be able to remove your head.
    SEi User
    81 HB LX, 84 HB S, 89 LX-i Coupe
    Indianapolis, IN
    My sentiments exactly. If it was in a n easy to reach area, then the weld would work, but you're spending serious time to get to the head. Do it right and not all ghetto.
    Knoxville, TN
    better head bolts?? were do you get those?
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Dead soft copper gaskets... something like that.
    anywho... just run a search on the net but I would think they would have to be custom... cause if i remember correctly our head bolts have grooves in them somewhere and the chance that anyone would have a matching bolt is slim.
    Nov 2002
    Ridin Dirty in New York
    if you get copper gaskets, most are supposed to be used on an o-ringed block... hey can we even get copper gaskets?
  1. can anyone weld alumnium???????
    By OldSkoolA20accord in forum Classic Honda Community Chat
    Last Post: 01-05-2009, 11:14 PM
  2. Pacesetter weld broke!
    By HondaBoy in forum Performance
    Last Post: 01-04-2009, 04:13 AM
  3. Universal weld-on engine mount bushings??
    By thegreatdane in forum Classic Honda Community Chat
    Last Post: 09-11-2008, 02:55 PM
  4. cast iron weld
    By custom in forum Performance
    Last Post: 07-27-2008, 07:49 AM
  5. JB weld
    By cl88 in forum 3geez Accords
    Last Post: 04-19-2005, 03:43 AM
