Hey does anyone know if a Carb automatic tranny will work in a Fuel injected car? Basically, I am asking if the two trannys are the same. Or is there a different gear ratio?
I know there is a slight difference in the gear ratios between the manuals and probably the same with the auto. Yes it will fit. Also look at the trany code to see if they are the same.
