I know that the Billsteins can make good struts if revalved, but they sure are on the expensive side..... are they our only hope?
I need these parts!
You beat me to this post carotman. I was going to ask the same thing.Originally posted by carotman
What else is there for us besides the Konis or revalved Billsteins?
:pissed: damn konis.
-=MIKE=-
Updated progress on my car weekly here-> http://www.cardomain.com/member_page...page_id=383034
i'll tell you what after hearing that the Koni's were bein discontinued i went out and got the KYB's. The car stil bounces like a mofo but it help alot also. i wish koni wouldnt of done that.
Cash
Rules
Everything
Around
Me
REPRESENT
Unless someone can find out if 88-91 civic sturts can work, yes the revalved Bilsteins are your only hope.Originally posted by carotman
I don't have a front 3g strut anymore and I'm going to sent off the rear bilstien's to DarknessRs(if I can remember to). So I'm not really able to pull a pair of 88-91 civic sturts to check. I did that with 92-95 civic sturts, no dice on those.
Do those years share the same suspension as a 90-93 teg?Originally posted by Jims 86LXI HB
That would be a car to look into also.
I read in another post that the revalved Billsteins are around $600. Is this true.
And how do go about getting them? Do you buy them revalved or have specialty shop revalve them?
-=MIKE=-
https://www.3geez.com/showthread.php?s=&threadid=18586Originally posted by Osiris
Mike
Well, I do have a spare 3g strut (1 front) and 2 rear)
I also happen to have a Winter beater, which is a Civic ED (88-91 Sedan)
I wanted to replace the struts on the beater since they were worn out..... I won't touch that before august but it's really something I'll look for...
I need these parts!
i have 3 spare koni fronts (2 are damaged) i can ask around at shops and see if anybody has 88-91 civic struts in stock so i can compare.
That would be cool. If there is only a small difference, the strut might fit but lower the car a bit more.. (or a bit less hehe)
I need these parts!
ok i just read in a thread here about the $2003 challenge that the guy used 88-91 crx struts (same as civic i would assume) and they were about 2" taller. coupled with 2" lowering springs it put the car at stock height and was stressing the struts a lot. he said it was ok for track, but wouldnt suggest it as a daily driver strategy. i dont know if this is good news or bad. i assume we could allways get them modified to work better, but then we are talking about $1000 again just for struts, when revlalved bilsteins are MORE than enough for most people
http://test.lowmotion.org/viewtopic.php?p=90966#90966
Here's a link to the 86-89 accord struts on a CRX. The front interchange with no problem BUT bad thing is like chris said, crx struts are 2inches taller. BAh. struts Dont interchange for the rears.
I'll try to dig up some info on the 88-91 civics
Edit: UPdated info..
http://honda-tech.com/zerothread?id=527474
guy in a 90 civic hb using accord struts I THINK. accord struts are 3 inches shorter overall and an inch or so shorter body than crx struts and 88-91 civic strut. the post is sorta confusing but I'll keep lookin
From what i understand, if you buy performance struts from the Civic (for the accord), then that will decrease the ride height automatically by 2 inches. Seeing that the struts are 2 inches lower for the civic. So if you have 1 1/2 inch lower springs then you now have a car 3 1/2 inches lower.
Am i correct?!
-=MIKE=-
NO, I think it's the other way around. the accord struts are shorter... bleh
however... I dont know if these struts would work from a 90-93 tegs
here's the link with a PICTURE!!!!
http://honda-tech.com/zerothread?id=534816
Do they look alike?
No, their's no way it would be lower, that I could deal with, our problem is the other way around. At this point without all the measurement's that I need in place we are 1inch taller and that is likely to show up in the area of not having enough strut down stroke travel, a very very bad thing. But I do not have a set of make or break measurements yet. Once I have them we will see what can be worked out to make them happen. It is my hope that the shorter bodied sport type struts will be able to work. But we aren't at a point where anyone should think about spending a dime on this setup just yet. We have a member that is actively working on this for us right now.Originally posted by Osiris
Am i correct?!
Ok goldy and Jim, gotta pick your brain a little more . So does that mean it will raiser our vehicle 2 inches.
Example... 1 1/2 inch springs + Civic struts = 1/2 higher.
Math... 1.5 lower (negative) + 2 inches higher = .5 inches positive (higher)
-=MIKE=-
If you were to talk about the springs.. yes. but the struts does not have any control in how high or lower the car is sitting. The spring controls that.Originally posted by Osiris
If we were to use struts from the crx's we'd have to raise the car 2inchs from stock to keep the stock travel of a crx strut.
I got this crazy Idea now that we could shorten the fork like crazy
Jim, What is this *actice member doing?* Is he checking the teg fitments or civic?
Josh
The problem is in tallness of the strut rod shaft itself. If it's taller the sooner you'll bottom out the suspension inside the strut itself. That tall shaft won't let the suspension travel where it normally would. Bad, very bad. lowering would only worsen the problem. It's not a problem caused or solved with what springs you use, unless you install tall one's and make a really high riding 3g.Originally posted by Osiris
Josh, civic fitment's. Over the counter parts. But not the shorter bodied AGX strut I don't think. That's the one I want to have a look at. But a standard civic strut is a good starting point.
I think that the 92-95 Civic struts are shorter
I need these parts!
Nope, those are the one's I pulled out of the junk yard and took home and compaired next to the 3g struts. They are taller. Somewhere I still have all the demensional info.Originally posted by carotman
The factory sturts aren't designed to let inserts be a viable option. I've seen some application guides that claim you might have to cut open the new struts to make them fit, but that's not the case for any strut made for the 3g. Beside's I've never seen or heard of Illumina, Koni or Bilstein sport or AGX inserts.Originally posted by PhydeauX
I would assume with the popularity of lowering those civics someone would be selling a short stroke strut. Also have you looked into gutting the shocks and sticking some inserts in?
andy
Sport struts for the 92-95 civic that I know of are Koni sports, Bilstein sports and the KYB AGX strut. Since the KYB's are the least expensive (at around $86 each) and are good to about 400lbs spring rates, that's the one I'd like get ahold of to measure. Right now we are trying to pin down the stock dementions to see if the shorter bodies can make it happen, fingers crossed.
Mine are crossed too.
