Results 1 to 4 of 4
Thread: Sensor dying but not dead.
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    Question Sensor dying but not dead.
    Got a Problem. When I come to a stop and in gear, my car tries to stall. I changed the fuel filter (got some bad gas) and checked vigorously for vacuum leaks. I also checked the whole ignition system for spark. Everything seems to look OK but it's obvious that it is not. The past couple of days, it's been getting this hesitation crap at highway speed as well. Then last night I was driving and noticed that the PGM-FI light started flickering and every time that it did, the car would hesitate, miss, whatever. When I got home I tried to check the ECU for codes but it showed none. Which this would make a bit of sense b/c it seems to be obvious that whatever sensor is not working properly, has not gone out completely.
    Does anyone have a suggestion on what this might be?
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
    2007 pilot
    Lv, nv
    Stalling and misfiring
    my accord had the exact same problem. in fact, it got so bad that everytime i came to a complete stop, the car died. well, i changed the spark plugs, wires, distributor cap, rotor, and it got better, but still somtimes died. finally, i had my mechanic look at it. he replaced the max air flow sensor (never heard of it), and the car has since worked fine. you may call me an idiot, but i think its a good idea to change all those things at the same time. it seems to me that changing just the plugs, would cause the plugs to become fouled if your cap is bad... or if your rotor is bad, it may screw up your wires. i dont know, someone tell me if im wrong. anyway, if none of that works, you can try chaning your ignitor. and (its a longshot) but there could be a short somewhere on the circuit that runs your fuel pump. i highly doubt that, because if there were, your car probably would not work at all, but that might explain your efi light or whatever coming on. keep in mind that my car is carburated, so i dont know if your efi will have a max air flow sensor. hope this is all of some help.
    -will
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Sounds like a clogged egr.
    Take it off and clean it.
    May 2003
    '86 LX-i Hatch
    Houston
    I'll check when I get home from work. I'll let you guys know if that works.
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. cylinder position sensor and TDC sensor
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 11-28-2006, 10:29 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Quick, Which o2 sensor is the primary sensor
    By 89accordlxi in forum 3geez Accords
    Last Post: 11-03-2002, 07:23 PM
