I have to re-boot an axle on my 86 LXI hatch.
I used to separate ball joints with a pickle fork, but I think it's a bad idea (unless you're changing the bj) cuz it can tear the boot (even if you're careful) & eventually kill the bj.
I've been thinking about buying a puller. I know that a lot of tie-rod/pittman arm pullers work for the tie-rod & our ball joints, but can I use a gear puller?
I've been thinking about buying the craftsman 2-3 arm convertible gear puller because I also want to be able to use it to pull the crank pulley off my friend's neon to do a t-belt (you NEED a puller for that job!). I don't want to buy 2 tools if I can get away with using 1 for both jobs.
Has anyone ever used one of these gear pullers with 2 arms to separate a bj on our accords? Will it also fit a tie rod?
Or do you think the arms will not grip right and slip when I try to separate the joint?
thanks a lot for any help.
