Results 1 to 10 of 10
Thread: Balancing
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Balancing
    I was quoted a price of 250 dollars for a crank balancing(I have to bring him the pistons, rods, crank and all the other goodies for him to do it). Although this might be a few months away, is this a decent price for such a job? Also with the mods I currently have would this be the next direction to head to? I'll get forged pistons and rods out of the deal too
    Just gotta wait for my monetary flow to increase.
    glorious!
    PhydeauX's Avatar
    Eastern Penna
    Make sure that when you bring the stuff to be balanced that you bring the stuff thats going to end up being in the car. The price can vary greatly depening on you're area, the shops reputation, etc... that seems like a fare price to me for a full balance job. Then again its been 3 years since I last looked into engine work.
    andy
    88 Accord LX sedan
    Galesburg,Il
    IMO balancing is a very good option, even if ya dont have an engine mods on the car. Just make sure like PhydeauX said ya take the machinist the parts going back into the engine, balancing wont work if you take the stock pistons, rods and flywheel in then try putting aftermarket rods and pistons on, youll just waste your money. Good luck
    *edit* lemme clarify this up alittle, when the rotating assembly is balanced ( pistons,rods, crank, flywheel and harmonic balancer) each part is "shaved" down to match the piston or rod with the lowest weight, i.e if one piston weighs 450 grams and another weighs 500 g, another weighs 475 g, and the last one weighs 455g, they will all be milled down to match the one that weighs 450 g, same for the rods. As for the crank they will take away and add metal to the counterweights to get it to within +/- 1gram of everything else.
    When ya get it all back and put the car back together you should be able to rev up alittle higher and should notice an increase in acceleration. Hope this helps.
    Hrm... I thought only V engine configurations came with harmonic balancers
    87 Lxi Hatch<-Blown Up!! 96 civic coupe
    Hot, Sweaty Florida
    Balancing will help quite a bit on moters!! WIth balancing a bottem end adding 11.0 compression on an h22 in an 94 accord go from 14.4 @ 96 to 14.0 @ 102 w/o drag radials!!
    Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
    Justin86's Avatar
    Medford, Oregon
    On a stock engine it won't madder much. But if you have heavy mods ie. turbo, and a lot of hp it will be worth it.
    88 Accord LX sedan
    Galesburg,Il
    Your right Mike, my bad, I was going on the assumption that the A20AA1 used a harmonic balancer.
    well the crank pully is sorta used as a harmonic balancer, ive heard lots of bad thing when people change them out for lighter ones etc
    Hot, Sweaty Florida
    i dont no about our cars butt h22s have balance shafts!! BC when my buddy got his crank full balanced he didnt need them!!! You can a little hp and tourque but also lets the moter tack up quicker and gets rid of grag on the moter!!!
    we dont have balanced shafts... F22s and H22s etc do i think. I dont know about d series engines but i doubt it.
  1. corner balancing :D
    By PeterNtheWolf in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-26-2010, 05:28 PM
