Results 1 to 11 of 11
Thread: Brake hose failure
    Mar 2003
    88 LX
    Vancouver BC
    Brake hose failure
    Both of my 88 accord (200k miles) front brake hoses have burst in the last 2 months resulting in almost total loss of braking each time. Isn't the system designed to maintain some braking ability when one of the four hoses fail?
    LXi User 89lxi95zx7's Avatar
    89 lxi 95 750 ninja
    Pittsburgh,PA
    there like $50 a piece too
    kevin
    I had no brakes at all when mine went. They are like 70 bucks apiece from Honda
    Mar 2003
    88 LX
    Vancouver BC
    They are free from the auto wrecker. I just look for one in good shape, after all, the ones on our cars are used anyways!
    I dunno, I wanted new ones. There are things you can skimp on, but I dont want to deal with another brake line burst on the freeway doing 80mph.
    LX User Darkside's Avatar
    Feb 2002
    A20A1 Weber Power
    Eugene
    Go for the stainlees steel line a coplete set is just over 100 bucks. Darkside
    DARKSIDE
    WEBER POWER!
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    Re: Brake hose failure
    yes, but seeing as its a diagonal braking system only 2 brakes would be working and with the fluid loss,you need to keep pumping the pedal to get any decent braking effect,(which usually isn't enough at times to stop)
    here in NZ, any brake lines/hoses that show any form of wear,automatically fails a warrant of fitness
    there had been incidents of passed WOF inspections where the brake hose has burst resulting in serious accidents in which the mechanic/s who passed the inspection was prosecuted and jailed
    Idaho
    That happened to me on my older 86 accord. The breaking of even one line, results in lost compression to the calipers and cylinders, which means no breaks. It's kind of like blowing on a straw with your finger covering one end and then letting your go really fast. Get the concept? The hoses are about $60 bucks.
    Also, If the fluid is gone, use your ebrake to slow down, like you do in the winter and snow to spin cookies. Actually if you pull up and down fast on the ebrake you can stop with out the brake pedal. I practiced after my lines broke. You get pretty good at it after a while. Plus you can have some more fun in the snow.
    LXi User bambamky's Avatar
    Jan 2003
    1988 Honda Accord LXi 4 door FI/1993 Toyota Corolla 4 door
    somerset,KY
    I have a brand new brake line on the pass side works fine
    2006 Nissan 350z
    Does school count?
    the way that the hydraulic system actually works is a split design, meaning separate circuits for the left front/rear and the tight front/rear brakes. Normally if one circuit fails, the other will remain functional and a warning light should appear when a lot of brake fluid is lost.
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    SEi User maxoutracer's Avatar
    Jan 2003
    1989 Honda Integra LS-ZC
    San Francisco, CA
    check your brake system and bleed it correctly, i would go with steel brake lines, you will noticethe diff. i'm currnelty running earl and you can't go wrong with it!
    JDM CONCEPTwww.jdmconcept.com
    1991 Honda Integra LS-Special
  1. Brake hose replacement
    By canadian357 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-14-2008, 10:58 AM
  2. Brake Lamp failure sensor question?
    By toaster13 in forum 3geez Accords
    Last Post: 04-13-2003, 12:43 PM
  3. Front left brake hose removal
    By martik in forum 3geez Accords
    Last Post: 04-11-2003, 08:52 PM
  4. brake hose
    By hondaisthebest in forum 3geez Accords
    Last Post: 10-08-2002, 08:15 AM
