ever since i replaced the alternator in my 88, the battery light has come on, but it seems to be doing a fine job recharging my battery. anyway, i was trying to do that test that it talks about in the accord manual, but i cant do it fully, because when i installed the new alternator, i broke the plastic arm on the alternator wiring harness, so i had to glue the harness in there. anyway, i pulled each fuse, and when i pull the alternator/fuel pump fuse, the light goes out. does that mean my alternator is still the problem? i doubt its my fuel pump, i replaced it like 1500 miles ago. also, sometimes the light will flicker, then just turn off. but the next time i start the car, there it is again, its becoming quite frustrating, not to mention confusing. any ideas? thanks
