Results 1 to 16 of 16
Thread: Smells Like... Burning
    DX User Matty_StyLz's Avatar
    1987 Accord LX (Canadian)
    Winnipeg, Manitoba, Canada
    Unhappy Smells Like... Burning
    It's been forever since I've posted here, however this is one time where I'm in need of help from fellow 3gee owners.
    Ever since I got my thermostat replaced early on in the winter, there's been an odd burning smell when I come to a stop. I see smoke rising from the engine bay, but every time I go under there, I'm unable to figure out just what the hell the problem is.
    It doesn't smell like oil burning, and I've checked everything that could leak. I'm thinking electrical of some sort. I'm at a loss now though. Any help would be appreciated. I'm trying to sell her in the near future.
    87 Honda Accord LX (AT, 159600 Kilometres)
    Color: Dark Metallic Blue
    Audio: Panasonic 60x4 Dot Matrix Display Head Unit, Alpine Type-R SPR-134A 5'1/4" 2-way front speakers, Alpine Type-R SPR-174A 6'1/2" 2-way rear speakers, 1 Alpine V12 300 watt amplifier, 1 Alpine Type-R 1240-D Subwoofer (enclosed box)
    Appearance:5''x3'' driving/fog lamps
    Performance: Nothing to speak of yet.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Well I would try seeing if it's a coolant leak from the thermostat housing. Is it white smoke or does it smell kinda sweet? the gasket might be bad on the housing. I used gasket maker silicone and it worked like a charm.
    I'll give that a check. No it's not white smoke. It's got a blue tint to it. But I'm almost positive that it's not oil.
    Jul 2003
    89 Honda Accord DX
    Fort Scott, KS
    read the other post about smoke from engine compartment, it has some good answers. It is from infecto and is called
    "smoke from front engine compartment" I geuss I should make retard noises now for sounding so obvious, anyway hope this helps, and don't sell it keep the 3rd gen accords alive they are one of the wickedest front drive cars with tons of support and they are relatively cheap to tune. mom has got one but I just got
    92 nissan 240sx that I am gonna plug sr20det in, and convert to a sileighty. I would have done more to accord but I like rear drive a little more and all-wheel drive the best. take it easy
    Winnipeg Manitoba, Canada
    Hows the coolant level? Is there a loss? Definately check out the gasket as it may be leaking from there. If you cant find it you should let me have a look at it!
    - Drive it like a Rental!
    My 89 Ex-i on Car Domain
    89 Accord LX-i coupe, Auto
    Missouri
    "Tastes like burning" lol, sorry, i had to. It's from the simpsons.
    "Turn off the television sets and eradicate the slander that says a black youth with a book is acting white." - Barack Obama
    1988 Honda Accord Coupe LXi
    Summerville, SC
    I bet you $100 its the high pressure line from the power steering pump. Seems like a real common problem as the car ages. First of all check your PS fluid level and see if its draining fast. Second check the line that runs in the front of the engine right above the exhaust manifold and feel to see if its wet at all. Also look at your shield on your exhaust manifold and see if its stained by smoke/fluid burning on it. It also could be oil blowing out of the valve cover but I doubt it.
    (Stock)
    Well if you'd come out to one of our HAVOC meets, then I would
    Summerville, SC
    Don't even comment on my suggestions
    (Stock)
    KaMiKaZeE's Avatar
    '73 Datsun 240Z/'91 300ZXTT
    Columbia, SC, USA
    Antifreeze burning has a strong smell to it, and the coolant level would be going down. I also think it is likely the power steering fluid, I had it leak in one of mine too. Check the level of the power steering fluid and see.
    KaMi's 1988 Honda Accord LX-I 5-Spd Hatch
    "Light travels faster than sound. This is why some people appear bright until you hear them speak."
    I've finally got a day off tomorrow. So I'm going to go over everything and see what I can find out. I feel it's more something to do with what Mike said though.
    It's too cooincidental that this started to happen the same day I got my heater core flushed and thermostat changed.
    Summerville, SC
    I still bet $100 its the power steering line. If it was radiator fluid it would be white and smell sweet like mike said.
    (Stock)
    87 Honda Accord DX
    Georgia
    what do you do if you think it is the power steering fluid because I lose steering fluid quickliy and there's no leak. Same with brake fluid too. I have all the same symntoms(sp?) as the guy who posted"smells like...burning".
    please help me
    Summerville, SC
    Well check that high pressure line in the front of the engine that is running from the powersteering pump see if its leaking....and brake fluid? Thats not good lol.
    (Stock)
    Well I did a good onceover of the car and found that it had absolutely nothing to do with the power steering or thermostat housing. What I'm pretty sure was happening was that I waseither getting some blowby on the ring side, or the valve stem seals were leaky and letting some oil get in.
    I changed to a thicker grade of synthetic oil for higher mileage engines.. and it's stopped.
    Nfld, Canada
    it's probably the goop used to reseal the thermostat housing to the block... too much of it I guess. I had the same deal... white smoke coming from the thermostat area after it was replaced. it all burnt off eventually
    WTB: 4th and 5th gen OEM headlights and corners in good shape. Even single lights.
    1995 Honda Accord EX-R | 1988 Honda Accord EX-i | 1987 Honda Accord LX (R.I.P.)
  1. 87LX No Start - Oil Smells like Gas
    By swiftymorgan in forum Carburetor Tech
    Last Post: 10-27-2011, 10:33 AM
  2. Cabin smells like pee
    Last Post: 04-27-2007, 03:07 PM
  3. smells like oil burning
    By RustyHo88 in forum 3geez Accords
    Last Post: 08-08-2003, 04:34 PM
  4. Help!!! a20a3 / overheating / burning smells
    By 87AccordLXiHB in forum 3geez Accords
    Last Post: 08-02-2003, 11:14 AM
  5. smells like gas under hood
    By Scotts88WhiteLX-i in forum 3geez Accords
    Last Post: 02-10-2003, 02:14 PM
