after days and days of pulling stuff apart, i finally started putting things together. my lights used to not retract, now they do. however, my cruise wasnt working before either. the main switch tested bad, so i stole one from a parts car (tested fine). before, my horns also were working. i replaced both of them, and they work, but they are considerably quieter than my 84 accord. anyway, my cruise still doesnt work, (the light in the instrument cluster doesnt turn on). im certain my main control unit works, and i also test the steering wheel switch, it was fine. so, what the heck is going on? all my cruise control components work, and so do my horns (although quietly). do my quiet horns have something to do with my cruise not working? i also discovered something kind of wierd. the circuit on the horns sends power through both wires to the horns when the horn switch is not pressed. then, when you press the horn, one of the wires stops sending power (making it a ground) and the horn is activated. is the circuit supposed to be that way? it wouldve made more sense to me if one wire was a permanent ground, and the other wire sent the power when the horn was pressed. is my wiring screwed up... or is there a problem somewhere else? is there a horn relay somewhere i can test? thanks.
-will
