Results 1 to 10 of 10
Thread: strange new problem
    hondamanlxi's Avatar
    Nov 2001
    huntsville, al
    strange new problem
    first ill list my setup as it might be helpful
    -deh 3400 cd player
    -preimier door/deck/tweets
    -boss 1000w 4channel
    -12" Autobahn sub
    Ive been having several strange problems that just appeared
    1) excessive distortion(and kinda skippy/choppy almost like a computer bogged down... can also resemble sound when wires touched together) at my regular vol level
    2) OCCASIONALLY everything but the rear amp "cuts out"
    3) its extremely hot here and that might be a factor
    4) all wires are properly connected and its not the cd!
    do you guys think its the head unit overheating?
    bad wiring? amp promblems? RCA malfunction?
    I havent forgotten my roots
    HostileJava's Avatar
    Northampton, PA
    Do you have another amp or headunit that you can throw in there and test to isolate the problem? Do you have a voltage meter? Maybe your voltage is dipping to low and causing the amps or head unit to shut off due to under voltage.
    Nov 2001
    huntsville, al
    wish i did
    ps.. does it without the amp
    LX User Osiris's Avatar
    May 2003
    1986 Honda Accord
    Waco, TX
    If everything is cutting out maybe it may be the alternator. Sounds like your pulling alot of power. Test the alternator. Or maybe your getting distortion from another wire. Are the grounds close to their sources?
    -=MIKE=-
    Updated progress on my car weekly here-> http://www.cardomain.com/member_page...page_id=383034
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    It's not your alternator, what it may be, however, is shorting speaker wires. Check your wire connections to each speaker, re-do them if possible and see if the problem rights itself.
    86 Lx-i Hb.
    sAcramento, CA
    what size guage is your power wire? maybe not enough current is passing through them . . and cuts our ur amp when not enough power when bumpin your beat. .
    - J u n i o r -
    Quote Originally Posted by 89ACCORDVTECH
    - One of my carS is an SEI A20 my LXI has AN H22
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Do you have a capacitor? Maybe you should get one if you don't already.
    LX User catalin's Avatar
    1986 Accord Hatchback
    Surrey, BC, Canada
    I'd say the same as 87DXHATCH, most likely a shorted speaker wire somewhere or it could even be a bad speaker.
    Nov 2001
    huntsville, al
    thanks guys
    more info...
    the promblem has reduced itself to the occassional split second cutout or static
    -4ga amp primary
    -grounded to the rear upper strut tower brace (first place is saw)
    -all connections are good but i havent checked the door speakers
    thanks for the help guys!
    ps could it be a bad speaker/tweeter?
    Nov 2001
    huntsville, al
    even more info...
    -door speakers good
    -does it with amp unplugged
    -only does it on cd mode (not tuner)
    its my head unit?!
  1. Strange problem on my 89 Accord
    By cbolyard in forum 3geez Accords
    Last Post: 01-25-2013, 05:14 AM
  2. strange electrical problem
    By lostforawhile in forum Carburetor Tech
    Last Post: 03-24-2007, 06:43 PM
  3. Strange but New Problem
    Last Post: 01-24-2004, 06:37 PM
  4. Strange engine problem, does anyone know what it is?
    By KaMiKaZeE in forum 3geez Accords
    Last Post: 10-15-2003, 09:23 AM
  5. 83 2nd Gen accord 1.6 problem...strange
    By max_chock in forum 3geez Accords
    Last Post: 07-24-2002, 05:05 PM
