I keep hearing of ecu codes what r they? How do get/read mine?
If your "Check Engine" light comes on, turn your key to the "On" position (the first click) lift the drivers seat forward, and remove the little plastic window on your ECU box, count the number of times the red LED blinks, report back here...
The GSX was killed, I need something new...
thanx, what if check engine light is out will it still flash under the seat?
i do not belive that the ecu will flash unless there is a problem with a sensor or the unit....no engine light or little flashing led's is a very good thing.......
89 accord LX-i , may she rest in peace
7/1989 build date
6/2000-4/2003 135624 Miles
:bh::pimp:
4/03-11/04 94 Saturn Sl2
11/04-03/14 2001 Hyundai Tiburon
3/14- now 2014 Dodge Dart SE
The need for speed is never satisfyed
Do you mean if its burnt out?? I don't see why it would'nt, the signal is still being sent, even if the bulb is out...Originally posted by Chrome_thangs
Thanx 88LXi
