Results 1 to 10 of 10
Thread: 1989 lxi front crossmember
    1989 accord lxi
    what year/ trim lvls will have the same crossmember as my 1989 lxi 4 door.
    crossmember = the piece that runs under the engine and both lower control arms mount into it.
    thanks
    fussell
    86 Honda Accord LXI HB 5-sp
    Central California
    I'm wondering why you'd think it would be different on any 3rd gen period? Unless we are thinking about some other part.
    Now I d
    shepherd79's Avatar
    Falling Waters, WV USA
    well,
    i think he is talking about sway bar.
    it is the only thing that connect lower control arms.
    if it is the sway bar, than stick to the oen from LXI. they have thicker one than LX or DX.
    LXi User BoredRec's Avatar
    Nov 2001
    1988 Honda Accord LXi
    Las Vegas
    Not only the sway bar, but the rear beam also has both lower control arms attached to it. Any 3rd gen beam will take it's place, nothing special or unique for that part.
    BoredRec
    1989 accord lxi
    i mean the part that the control arm actuall mounts onto, not just what is attached to it, sway bar just attaches to it
    peace
    fussell
    Nov 2001
    Las Vegas
    Yeah, that would be the rear beam.
    1989 accord lxi
    in the front though, so the front beam?
    if you mean the crossmember in the rear that the lower arms bolt to (part #2) yes they are the same I'm pretty sure, if for some reason they WERE different it would probably fit anyways, they are all the same width.
    Eric
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    This is what you mean right? Under the CV joint where it meets. They are all compatible
    http://vtecnos.tripod.com
    Member Since 7-9-01
    1989 accord lxi
    yup thats it, i started taking it out of an 89 lx in the yard yesterday but i got rained out after i got it blocked up. it has some rust on the ends but i figure i can just clean it and repaint it before i put it back in. it looks stuctualy sound. if anyone has any tips on how to get it out plz tell me, ill be going back monday if it doesnt rain.
    peace
    fussell
  1. Help with completetion of custom front crossmember
    By mykwikcoupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-04-2013, 10:31 AM
  2. Replies: 2
    Last Post: 04-29-2012, 10:16 PM
  3. Pacesetter hitting my front crossmember
    By codyJDM in forum 3geez Accords
    Last Post: 10-24-2008, 05:19 PM
  4. front crossmember for '85 accord
    By Lori Caterini in forum 2geez Accords
    Last Post: 06-30-2006, 07:34 PM
