Results 1 to 8 of 8
Thread: clutch problem
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    clutch problem
    well..my friend is planning on getting a 3g we found its an 88 lxi like mine and he found it for 1500. The only problem with it is when you get on the gas hard in any gear other then second it revs but doesnt really go anywhere. Its like the clutch is engaged a little bit. i wanna figure it out quick because we plan on driving to six flags next saturday and want to make sure the cars are set..so if the thing needs a clutch then i wanna get it done quick or if it could be adjusted or something....so any help would be great..
    1988starter
    Guest
    There is a black nut like thing near the fron the of engine bay that you use to ajust the clutch cable it is infront of the tranny give it a try and see what happens.
    shepherd79's Avatar
    Falling Waters, WV USA
    it is probably needs a new clutch. my car used to do that when i got it. i was adjusting till i couldn't do anymore.
    try adjusting it frirst.
    Feb 2003
    NH
    thanks guys
    Feb 2003
    NH
    one last question..am i turning this thing to the right or to the left? it may sound dumb but the adjuster is right in the middle of the thing and i want to be sure..thanks again...
    Feb 2003
    NH
    nevermind...i decided to try it and figured it out..woo
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    You need to unscrew it (counter clockwise) to make sure that the cable isn't preventing the clutch from fully engaging. Once the release arm has some movement (1/4 - 1/2 inch is fine) before the clutch cable is stretched tight, adjusting it an more will not help.
    Mike
    Jul 2003
    1989 SE-i
    Upstate NY
    had the same problem, guy i bought it from assumed it needed a clutch. just a few turns and the clutch holds strong as can be.....
  1. 89 prelude clutch pedal or cLuTcH problem!?!
    By myaccord7 in forum Classic Preludes
    Last Post: 10-14-2006, 10:45 AM
  2. Clutch Problem
    By CletusWindu in forum 3geez Accords
    Last Post: 07-11-2004, 07:35 AM
  3. clutch problem?
    By DLB in forum EFI Tech
    Last Post: 06-23-2004, 11:39 AM
  4. clutch problem
    By seancornelis in forum 3geez Accords
    Last Post: 04-24-2003, 03:34 AM
  5. starting problem,or clutch problem
    By LIL'LXi in forum 3geez Accords
    Last Post: 11-26-2002, 09:12 AM
