Results 1 to 7 of 7
Thread: Any way of fixing the oil pan drain plug? Or should I replace it
    Jul 2003
    Well, my oil pan has no leak from the gasket. Only problem: the drain plug has been stripped. From what I know, it was stripped before, then it was tapped, and then its stripped totally. I think its about 1/2 inch, because I would buy the 1/2 rubber drain plug, and it fits in there perfectly. My question now is : Can I do anything else to this drain plug? I don't like the idea of using this rubber plug( its unsafe in my opinion). Can I buy a self tapping screw before than 1/2 inch? As well as, is it POSSIBLE to remove the oil pan? I know you have to remove the pipes, that should easy. Is that all to remove that's an obstacle in taking out the pan? Any suggestion would be appreicated.
    Legend9
    Made in Japan
    Oct 2002
    Autoparts stores carry drain plug repair kits. The other way is to find a slightly larger plug than the one you have now, and tap the drain hole larger to fit it.
    Jul 2003
    Hi, thanks for the comment. The problem is that I brought a car to a friend who is good with cars. He told me he cannot tap anymore. I think its touching the metal now, no teeth left. How is it possiblet tap the hard metal of the pan ?
    Made in Japan
    if you go to the autoparts store, you should be able to buy oversize drain plug. it will tap itself.
    Jul 2003
    Ok I will give it a go. Will that part be at the screws section, or it has to be through one of the guys that carry them in the storage section with other important tools ?
    Made in Japan
    Oct 2002
    Taps are made of hardened tool steel, so they'll easily cut new threads in the reinforced section of the drain plug hole. It's easier to use the plug Alex mentioned. Saves time and they don't cost that much. If you can't find one in the oil change section, ask the parts counter people. If they don't have one, they can order it. It's a pretty common repair.
    Jul 2003
    Ok thanks. I will go to Autozone and ask them. My question now remains : the hole in my oil is 1/2 inch. Do I buy the screw 1/2 ? Or a lot bigger? Second question is : these "self-tap" mean I don't have to buy a tapping tool correct? Just screw these in and it will stay in ?
    Made in Japan
  1. coolant drain plug
    Last Post: 11-11-2006, 09:41 PM
  2. oil pan drain plug stuck in
    By mykwikcoupe in forum 3geez Accords
    Last Post: 01-19-2004, 09:26 AM
  3. oil pan drain plug stuck in
    Last Post: 01-17-2004, 06:15 AM
  4. Gas Tank Drain PLug.
    By Dibbs in forum 3geez Accords
    Last Post: 11-12-2003, 10:00 AM
  5. Where's the radiator drain plug?
    By 89NinjaAccordLX in forum 3geez Accords
    Last Post: 07-08-2002, 06:48 PM
