Results 1 to 11 of 11
Thread: Window Stop??
    LXi User StUpiD8000's Avatar
    89' LX-i coupe, 09 Mazda 3I
    MID-OHIO
    Window Stop??
    I just put a new set of speakers in the doors but I cant put my window down all the way. Just about 3-4" not much...Anyways What is it that makes the window stop when it dose? I was just going to make or rig someting so I dont fucup my speakers...
    SEi User MattsAccord's Avatar
    Feb 2003
    1986 Honda Accord LX
    Southern Oregon, Medford
    Do the speakers stick out to much inside the door? I would check that first. Sometimes the speaker is to deep.
    MID-OHIO
    yes the speakers are too deep.... Thats why I need a way to make the window stop at a set point not all the way down.........
    Feb 2003
    I didn't read that very well sorry. Well my window is a messed up and somewhere in the gearing teeth are missing so I don't know if you could just do something like that. Sorry the the very little help.
    Jul 2003
    87 honda accord
    medford' by way of lbc ca
    HOW FAR DOES YOUR WINDOW GO DOWN
    dogg213
    Take off your door panel and then take off that plastic crap under it. On the upper right (or left if its the driver's side) there should be two bolts which line up horizontally. You can move these up and down and it adjusts the window. I would try that first
    the auto window is regulated by a black box in the upper part of the driver's side door by the mirror
    Eric
    MID-OHIO
    That will adjusts where the window is going up and down wont it?? I am going to try that and see what it dose.....
    I'm not sure what you mean. On my car, I had to adjust it because the window was very hard to roll up and down because it was pushing against one side. You can mess around with it and see what it does. It also makes it stop where it does... like mine would stop all the way down, but now it sticks up a little. I still need to adjust it so it doesnt do that, but I'm too lazy.
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    Here's what you should do:
    Get ahold of some 3/4" plywood of some sort, try to keep it quality. (You do NOT want MDF). Cut a 6.5" ring out that will fit over the mounting spot in your stock speaker basket. Screw it to your speaker basket and attach your speaker to this, it will allow your window to go fully up and down.
    MID-OHIO
    I cant..The stock grill wont fit with the speaker up on the wondow even...(5"deep) so Im glassing something.....Should be done by tomorro....Hummm I do need to know how to get all that stuff out of the back deck......?
  1. non stop blinkers
    By johndej in forum 3geez Accords
    Last Post: 12-18-2006, 03:29 PM
  2. Stop, look, what's that sound?
    By Not like a rock in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-06-2005, 09:10 PM
  3. RAD stop-leak
    By Vanilla Sky in forum 3geez Accords
    Last Post: 12-09-2004, 10:08 AM
  4. Vibration when I come to a stop.
    By Silver86LX in forum 3geez Accords
    Last Post: 06-16-2003, 10:12 AM
  5. Well It ever stop (IDLE)
    By LyFeWoRx in forum 3geez Accords
    Last Post: 04-16-2003, 12:52 AM
