Results 1 to 24 of 24
Thread: trunk rattleing
    87 accord lx
    Denver, CO
    Unhappy trunk rattleing
    my trunk lid wont stop rattleing.. i have extreme dinomat on the lid and the regular stuff on the floor.. i also have a towel stuffed behind the licence plate and it still rattles.. what else can i do to make it stop???????????
    SEi User damackz's Avatar
    Oct 2001
    86 Accord Exi
    Vancity BC Canada
    what exactly rattles?!? the trunk lid itself?
    86 Electron Blue Accord Exi
    3geez Member since October 31st 2001
    1987 Honda Accord LX
    Toronto - CANADA
    how many screws to u have in urplates??? I have one and the other is broken off, and when i pump my fosgates it rattles like crazy!
    Hope this helps.
    Phil
    DX User philendrick's Avatar
    1989 Honda Accord LX-i coupe, Monterey Green Metalic
    Nashville, TN
    Re: trunk rattleing
    When I had my 86 honda, rattling was much worse than in my new car. You should be able to identify the source of the rattling by cranking that SOB up and listening. first try with your trunk open, then shut the trunk and fold down the back seat. Get in there if you have to, and listen, and look. You'll figure out where it's coming from. If the lid itself is rattling, make sure the rubbler adjusters / stops are in place and the latch is adjusted properly and not loose.
    My rattling turned out to be the bars under the deck that raise the trunk. in the older models, I don't believe they had the plastic piece that seperates them in the center. It only rattled when it was shut, so I shut it, climbed in the back seat, and there it was... so I put padding in between those bars...
    Hope that helps.
    Philip
    The 1989 Honda Accord - "Take a grip of steering"
    87 accord lx
    Denver, CO
    i think its the plastic piece where the licence plate is on.. th e black piece. can i remove it and stuff like towels back there or something????
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    what I did on my old car was got a roll of some of that foam weather stripping, has the adhesive on one side. It worked well for me.
    -Aaron-
    DX User Matty_StyLz's Avatar
    1987 Accord LX (Canadian)
    Winnipeg, Manitoba, Canada
    I've got the trunk rattle, and really there's not much you can do about it. What it is, is the tw peices of metal used to create the trunk rattling, combined with several other things.
    As far as the lisence plate goes, I don't see why you're hacing so much trouble. I got some bubble-wrap, cut it to size, and screwed it in behind the plate. I then stuffed some more beheath the plastic to limit the vibration. It is almost impossible to stop rattling alltogether.
    87 Honda Accord LX (AT, 159600 Kilometres)
    Color: Dark Metallic Blue
    Audio: Panasonic 60x4 Dot Matrix Display Head Unit, Alpine Type-R SPR-134A 5'1/4" 2-way front speakers, Alpine Type-R SPR-174A 6'1/2" 2-way rear speakers, 1 Alpine V12 300 watt amplifier, 1 Alpine Type-R 1240-D Subwoofer (enclosed box)
    Appearance:5''x3'' driving/fog lamps
    Performance: Nothing to speak of yet.
    DX User XBLCanterX's Avatar
    Lexington, NC
    If you open the trunk and look up underneath the rear deck, youll see two black rods that run the width of the trunk. These were the culprits that were rattling in my trunk...they were vibrating against the metal. I just stuffed some cloth in between the rods and the metal and it helped alot. Also it might be the brake light inside the car on top of the rear deck rattling against the back window...what i did to fix this was I jammed a small piece of carpet (about 1'' square) that I used to cover a box I built, up underneath the light housing itself between it and the deck. this seemed to help the rattling tremendously.
    1988 honda accord lxi coupe
    ny
    plates
    see if u can drill 2 more holes for the bottom of the license plate. thats my problem u need at 4 screws
    shepherd79's Avatar
    Falling Waters, WV USA
    i had the same problem till i took the lights on the trunk and putt dinomat extreme. I even putt dinomat on license plate, used 4 screws, putt dinomat on trunk lid and took plastic sides and putt sticky foam on the bottom of plastic panels, and on every thing that had contact with metal. i don't have the dinomat on the bottom of my trunk ( i run out of it, i am gonna putt it as soon i find some time). I still get ratle on the back desh, but i think by pulling it out and putting dynomat should help.
    10/Honda/Ridgeline
    NJ
    the other thing that rattles on mine is the carboard-carpet thing that runs from the left to the right rear speakers. that thing has a gap below it and to the body of the car and just wont stop vibrating. i am planning on getting the regular household carpet padding and put underneat it, besides that, nothing rattles or maybe its cause i dont have a sub. BUt i did notice the rattle of the trunk or to say the spoiler on my friend's 96 mustang. He has two infinity subs and that thing is loud, but no bass. Probably he did not fiddle with the crossover, so anyways. like ppl said. try either making something to hold the vibrating thing hold down, or having something underneath it to dampen it. do tell us if u succeed and get a how to on that. thanks man
    1988 Honda Accord
    Ontario, Canada
    I FIXED MY RATTLING!!!
    I just turned down the stereo
    heheheheh j/k
    CoAsTeR
    10/Honda/Ridgeline
    NJ
    ur crazy as always coaster :p
    1988 Honda Accord
    Ontario, Canada
    I aim to please :p
    CoAsTeR
    88' Honda Accord LX
    www.coastersride.cjb.net
    Visit my website for pics and how-to's
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    I think XBLCanterX nailed it... it is usualy the rear brake lights including the one on the rear deck... as well as someone mentioned the upper trunk lid... bars, latck etc... good luck....
    Nov 2001
    sorry.. *latch....
    1987 accord lx-i
    utah
    its generally in the trunk lid when its open it doesnt come from any where but the trunk lid and if you push on it it stops but i can only hear this outside my car cuz inside the musics to loud and dont think its just the three ge cuz its not every car with a stereo system has a rattle unless they have went through selled up every hole and tightened every bolt and dynomated every knook and crany
    hmm and you thought the reverse polarity of the sun made you loose to a 3rd gen accord
    89 LX 5 speed
    Florida
    I had the same rattling problem...it was the two bars under the panel where the rear speakers are mounted..stuffed some pieces of cloth between them...tada! no rattling...just pure lows...
    LX User 89AccordGSR's Avatar
    N/A for the public eyes;)
    Orlando, Fl
    There is this invention called DYNAMAT, it works wonders.
    Plans have changed....The car is gone & im on to a new project....Nissan Maxima & 240sx/S13 Silvia....But the modders of the 3rd Gens still have my props. Not to many other cars take tha drive to do like a 3rd Gen
    Nov 2001
    I second that!!!!
    ~Nathan~
    "There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
    ~StOcK PiCs~
    1988 Honda Accord
    Ontario, Canada
    dynomat is expensive too... is there a substitute that I Can pickup at a fabric store or something that is cheaper, so I dont have to pay for the damn name?!?! heheheheh
    CoAsTeR
    88' Honda Accord LX
    Orlando, Fl
    Lets put it this way. Say that you decide to upgrade your setup. Say to 15s or a different company name. If you install fabric or what ever it wont hold for vary long. Dynamat on the other hand is expensive, but its worth it. Not to mention Dynamat is like a reflector for bass. So with the fabric, its going to absorb sound & if your like me you want the full sound quality out of your system.
    But, its not my ride so do as you please.
    Nov 2001
    hey GSR... whats your sound setup like???
    also... a friend of mine just bought the MR-7's in gunmetal 205/45-16's.... I'll post some pics if you're interested.. its on a corrolla...
    ~Nathan~
    ~StOcK PiCs~
    Orlando, Fl
    My setup in my Accord is all stock. Right now my Accord is in the shop getting engine work done to it. So funds other than major fix ups have stopped. Once all that is done though, my audio phaze will start back up and I will keep everybody post with installation & Db meter pics. Heres is my future list for anybody who want to know. The only time that ill have rims smaller than 17s, is when im racing & those rims are to nice to race on.
    Pioneer DEH-P9300 headunit
    (two) 6.5 Audiobahn ABF26Q-120w full range speaker
    (two) 6x9 Audiobahn ABF39Q-165w full range speaker
    (two) Audiobahn AMD60 midbass subs
    Audiobahn AKIT2 power wire
    Audiobahn A6601Q amp-150 watts x 6 @ 2 ohms (running the full range speakers & component speakers)
    Audiobahn A2300HCQ amp-1200 watts x 2 @ 1 ohm (running one sub on each channel)
    (two) 12" AW1206Q compression subwoofers-1,100w subs
    (two) Audiobahn AFRG15C speaker grilles
    Audiobahn AEQ7 equalizer
    (two) Audiobahn ACAP50 capacitor
    (three) Audiobahn AVM150 monitor
    Pioneer XDV-P9 dvd player/cd changer
    Optima yellow top battery
    double sheets of DYNAMAT through the whole car
  1. flip flop trunk trunk lights shaved
    By 2dsei in forum Interior & Exterior Care
    Last Post: 05-22-2005, 09:28 PM
  2. Trunk lid help
    By $40089'accordproject in forum Interior & Exterior Care
    Last Post: 08-22-2004, 03:26 PM
  3. will a 4G trunk lid fit on a 3G?
    By SharkyX in forum Classic Honda Community Chat
    Last Post: 07-11-2004, 08:50 PM
  4. 90-93 trunk????
    By KoNEY in forum Interior & Exterior Care
    Last Post: 01-12-2004, 05:37 AM
  5. WTB: Trunk lid
    By kicker1_solo in forum Trading Post
    Last Post: 07-02-2003, 10:51 AM
