Results 1 to 3 of 3
Thread: Unstable Idle
    May 2003
    Unstable Idle
    Hi!
    My car(A20A2) have a very unstable Idle,from 250 rpm-1000 rpm .And idle is sometime not stable at one place..I think it should be stable at 700 rpm,i belive that i need to adjust the idle screw to get the desired idle..Should i just find the idle screw and screw it clockwise to adjust the idle to 900 rpm?
    How do i use carb cleaner,can i just spray the on the carb?
    My car starts and runs fine..just the idle that is unstable.Anyone here who have sugesting,i have replaced the fuelfilter,fuelpump,spark plugs,distributor,replaced the fuel filler pipe and cleaned the fuel tank..
    Anyone have any sugestion,what the problem might me,and what can be done..
    Accord 1986 EX
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    You lift the air cleaner lid and spray the carb cleaner at the gold colored screen in the middle... remove the filter first so you don't end up spraying the filter by accident.
    You could have a small vacuum leak somewhere... the idle screw should be on the left side of the carb... but since you have the A20A2, the idle diaphragm might be facing a different direction.
    89 Accord LX
    Mesa AZ
    Unstable Idle
    REPLACE YOUR PCV VALVE!!!!!!!!
    Mods:
    32/36 weber dgev
    accell super stock coil
    vacuum lines removed
    pacesetter header
    carsound highflow cat.
    biohazard racing muffler
    delta 272 Cam
    Rebuilt engine
  1. Replies: 18
    Last Post: 11-03-2009, 05:42 PM
  2. Unstable Timing
    By ELM'sLX+CHL'sDX in forum 3geez Accords
    Last Post: 10-13-2005, 10:35 AM
  3. car feels unstable on the road
    By rdn in forum 3geez Accords
    Last Post: 04-02-2005, 12:07 PM
  4. car feels unstable!
    Last Post: 06-18-2004, 03:37 AM
  5. Weber Carb - cold idle fine, warm idle too high - help?
    By it's paid for in forum Carburetor Tech
    Last Post: 02-21-2004, 09:11 PM
