Results 1 to 12 of 12
Thread: weber pplz
    89 Accord LX
    Mesa AZ
    Question weber pplz
    hey i got a question for the people that did the weber install. where did you drill the hole for the throttle cable in the linkage? what holes was it in between because i dont think im getting WOT out of it. there is still some room for it to open. and i cant get the cable too tight because then the return spring isnt tight enough to keep it from idling too fast. If someone could let me know what worked for them that would be cool.
    thanks again
    james
    Mods:
    32/36 weber dgev
    accell super stock coil
    vacuum lines removed
    pacesetter header
    carsound highflow cat.
    biohazard racing muffler
    delta 272 Cam
    Rebuilt engine
    89 Accord LX
    Mesa AZ
    weber pplz
    also does anyone know what gm idle solenoid to get for the AC?
    Mods:
    32/36 weber dgev
    pacesetter header
    delta 272 Cam
    Rebuilt engine
    GM? why...
    Anyways... right where the linkage bends to clear the nust that hold the linkage to the throttle shaft... that is how low you drill the hole... and you drill it as far away from the throttle bracket as you can. First though you need to get a hammer and flatten the linkage so you can drill in the spot where the bend was.
    89 Accord LX
    Mesa AZ
    weber pplz
    thanks mike that helps. hey you wouldnt happen to have a pic would you? so i just straighten that little bend in it then drill where it kind wraps around the backside of the nut? i think i know what your talking about.
    Mods:
    32/36 weber dgev
    pacesetter header
    delta 272 Cam
    Rebuilt engine
    PhydeauX's Avatar
    Eastern Penna
    The actual formula to figure out where to drill it is this:
    Cable length is how much longer the cable is when the accelerator is up then it is when its pressed to the floor.
    Radius is how far from the pivot point the hole should be.
    You'll also need to put a couple of washers behind it to keep it from binding the on the linkages once you've flattened it.
    andy
    Okay I'm going to move this to carb tech...
    Thanks PhydeauX,
    A pic is worth a 1000 words... and I know I've seen you post this at least twice before.
    89 Accord LX
    Mesa AZ
    you shortened your cable though mine is still stock length. instead of putting a cable end on it i just split the braids and put it around the stud and tightened the nut. that would make a difference wouldnt it? and thanks for the pic PhydeauX.
    Mods:
    32/36 weber dgev
    pacesetter header
    delta 272 Cam
    Rebuilt engine
    cut the cable and do it right.... thats all I can say.
    BTW what he's using isn't a cable end... it has a pivot on it so the cable does not kink when you press the gas.
    If you bolt the cable straight to the linkage you'll eventually wear out the cable and it will snap.
    89 Accord LX
    Mesa AZ
    well what kind of end should i use for it? i didnt want to cut the cable incase i ever sold the car they could put all the stock stuff back on. i still have everything. but i think ill keep the car until it is dead. i still have a long way to go. but yeah anyways what type of end do i need to get or do i use the one that came with the kit or what? thnx for the info mike.
    Mods:
    32/36 weber dgev
    pacesetter header
    delta 272 Cam
    Rebuilt engine
    89 Accord LX
    Mesa AZ
    see thats not the kinda end that came with my kit. its different where could i find the swivel one? you know im probably not getting alot out of my car. ill try and post a pic and show you what i got.
    Mods:
    32/36 weber dgev
    pacesetter header
    delta 272 Cam
    Rebuilt engine
    PhydeauX's Avatar
    Eastern Penna
    I got that one at abc discount auto. Its actually a cable end that I hacked into a pivot anchor because I lost the one that came with the kit. Just cut the end off the cable and unbraid one strand from the part that goes through the cable anchor, its too fat to fit otherwise. The throttle cable is easy enough to replace if you ever want to put the car back to stock.
    andy
    89 Accord LX
    Mesa AZ
    weber pplz
    hell yeah ill just do that then. thanks homie.
    Mods:
    32/36 weber dgev
    pacesetter header
    delta 272 Cam
    Rebuilt engine
  1. k-726&k-728 Weber Help
    By Gentry09 in forum Carburetor Tech
    Last Post: 01-11-2013, 07:57 AM
  2. 38 weber Q&A
    By zigzag in forum 3geez Accords
    Last Post: 03-28-2009, 05:47 AM
  3. Replies: 93
    Last Post: 04-25-2008, 10:42 AM
  4. weber & a/c, can i get a what what?
    By seancornelis in forum Carburetor Tech
    Last Post: 08-29-2003, 12:04 AM
  5. weber pplz
    By thundertank in forum Performance
    Last Post: 07-29-2003, 10:52 PM
