Results 1 to 10 of 10
Thread: Thermostat housing Question.
    May 2003
    1987 Accord LXi Hatchback
    Kunkletown, Pennsylvania
    Question Thermostat housing Question.
    I was wondering if anyone knew what the little vacuum sensor does that is screwed into the back of the thermostat housing does, and has lines 3 and 12 running into it. I'm curious to see if a malfunction with this would cause problems with idling.
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    umm. I broke mine and it doesn't have any problems with idle. Does your check engine light come on? How long has it been since a new tune up? Normally that doesn't mess with your idle.
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
    i think its a vacuum thermoswitch but i cant remember what it does... its like some kinda wax valve
    '88 2.0i EX
    Ukraine, Kiev
    This is thermovalve of evaporation system. This valve open, when engine temp is above ~55 Celsium and allow manifold vacuum (line #12) open purge control valve ( by #3 line).
    McNick (UA)
    May 2003
    Would a malfunction with this valve cause problems with idling. i.e. : Rolling idle, High idle...
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    by-pass the thermo-valve and connect the 2 hoses together to see if theres a difference
    '88 2.0i EX
    Ukraine, Kiev
    ... or block both hoses to see if theres a difference.
    McNick (UA)
    Idaho
    It might cause high idling. I believe if you take off the egr valve hose the idling will go higher, so it could make a difference. You'd have to use a vacuum tester and see how much psi is going through the lines. good luck.
    '88 2.0i EX
    Ukraine, Kiev
    EGR (exhaust gas recirculation) is not the evaporation system. Last one control the flow of fuel tank gases to intake manifold.
    McNick (UA)
    LX User Shin87LXI's Avatar
    Feb 2003
    1998, 1993, 1989 240sx / 94 RX-7
    Funny,
    After a 3rd transmission install, I too broke this thermostat connector. Where can you buy a new one? 87 LX-I exclusive?
  1. 89 LXI Thermostat Housing
    By snyper1982 in forum 3geez Accords
    Last Post: 04-02-2008, 12:50 PM
  2. Thermostat housing
    By paulwwww in forum 3geez Accords
    Last Post: 01-12-2008, 07:53 AM
  3. Thermostat housing problems.
    By Blazin in forum 3geez Accords
    Last Post: 07-30-2007, 04:58 PM
  4. WTB Thermostat housing
    By Immeraufdemhund in forum Trading Post
    Last Post: 06-27-2003, 10:04 AM
