I posted a while back saying that my engine had a problem with missing. The PGM-FI light would flash on for a few seconds then when it went away the engine would miss. The car usually stalls at idle too. I think it was POS Carb who said to clean out the EGR tube and valve. Although I have not gotten to that yet, I plan to do that tonight. Is there anything else you guys think I might should check since I'm under the hood?
BTW...What's the best way to remove the EGR tube and valve? I see a lot of hoses and wires above the tube and it looks like a bitch to take out. I thought about disconnecting it from the EGR and using this long ass brush on a wire that I have, then spraying it w/carb cleaner to loosen the rest up and let it push on throught the exhaust (I have no Cat). Any other ideas would be helpfull. Thanks.
