Hi Everybody,
I 'have a 88 Accord DX (carb) with 209kmi. Following an alt failure at 170kmi, I got a rebuild unit, on which I've already replaced once the regulator.
After replacing the alt, I ran into different problems:
1) alt light would go on while engine running depeding on whether condition (!), usually when cold outside. I also had at that time idling problems. I figured out the choke heater was shorted and replaced it. Idle pb is gone together with lamp glowing in the cold.
2) On very hot days, with A/C on, at about 4000 to 4500 RPM, lamp glows sometimes on and off. Can't always reproduce the problem. Could'nt figure out what it was. I thought it could be a ground trough ECU due to a bad TW sensor, I replaced the TW sensor, but the pb is still there....
3) I now have another pb: with ignition ON, and engine OFF, the light just goes on for 1 sec and then goes off, altough it should be ON. Alt seems to be charging fine (14.8V at the battery with high loads.) I checked the input to the (IG, L, and S), everything seems fine. Can't figure out what causes the lamp to goes off: it could be either the voltage regulator L connector going to 12V, or whatever is on this circuit (Choke, ECU/EFE heater) going to 12V.
Any ideas on pb 2) or 3)??
Thanks, thoses pbs are really driving me crazy!
Would you have any idea on pn 1) and 2)![]()
