Ok, ive read post after post, and everybody seems to say the same thing.. Mechanical problem!! But what are the chances of an electircal problem?? I have a rebuilt engine, the head was plained, and a new gasket was set for it. Ive had the head tested, and the cooling system pressure tested. No problems there. So heres the situation. My car will over heat, but only at an idle. If im moving, coolant still circulates. So, i take my car in, and they say, its an air block, so we bled my lines, its all fixed. For a month, then, i was back there, he showed me how to do it, and now im doing once a week. So, he says jump the plug on the sensor unit (bottom of the rad) and he says the fans should turn on, but nope. No fans for me, and i cant seem to get the wires from the fan motor disconected, so i can try to hot wire, and figure out if the motor is shot, but i dont think it is, cuz after bleeding, (sometimes) it fixes the problem. So, i really dont know what to do. Any ideas?? Also, i was told to set my timing, as that could affect my cooling system, and thats fixed. And i had a problem with my throttle cable, thats fixed now too. Any ideas?
