this may help those trying to get that pesky relay out.
1) remove access panel and coin holder
2) remove 2 10mm nuts from either side of the fuse box and pull it off and let it hang to the side (you may have to unplug some wires to do this)
3) with a flathead screwdriver, unplug the relay
4) using ratchet and extensions, remove single 10mm bolt and remove the relay.
5) take relay and HIWAFH!
