Results 1 to 13 of 13
Thread: Amp, Is it stable?
    LXi User 88LX-iSedan's Avatar
    1992 Infinity Q45 - 1996 Nissan 240SX
    Kingsport,TN
    Amp, Is it stable?
    Alright, I found a RF Power HX2 (Dual 2ohm) with a box for a decent price.. But, I want to know if my amp is stable down to 1ohm. I'll be wiring it in Parallel so i can get the most out of my amp sence the RMS on the Sub is 1,000Watts and my amp is 800Watts Bridged, Not sure at what ohms though... The amp is Crunch DS-4002, If any of you know if it's stable.. Lemme know. Thanks
    Edit: Nm, I sent an email to Crunch Support and asked the question.. Hopefully i get a reply
    Edit..Again: From what i've come up with the amp would push waay to much for the sub at 1Ohms, That's if the amp is stable at 1Ohms and if i've figured this up right so far. ..Here's what i have determined,
    400 x 2 @ 4 Ohms
    800 x 1 @ 4 Ohms
    600 x 2 @ 2 Ohms
    1200 x 1 @ 2 Ohms
    800 x 2 @ 1 Ohms
    1600 x 1 @ 1 Ohms
    ...Im already starting to believe it's not Stable at 1 Ohms sence it's not a Mono Amp.. Oh well, Doesnt really matter now anyway.
    sorry man, but it is not stable at 1ohm.
    Kingsport,TN
    Cool, Thanks shep. Guess i'll stick to finding a good deal on an Audiobahn AW1206T (Dual 4 Ohm) and wire it bridged parellel to get a 2 ohm load, I'll have to turn the gain down some.. But, i'am sure one will blow my 2 RF Punch's that are 3 years old away with the right box. My brother just had his system tested and he hit a bit above 130DB, My system hits hella harder than his.. So no telling what im hitting at now. If i don't find any good deals though, I'll do fine with what i have.
    LX User KoNEY's Avatar
    Jul 2003
    95 Skivic Cx HB
    Winchester, TN
    dude, just ditch that damn crunch amp n get a better one
    or, just get another one, and bridge one on each coil, it;ll take it
    Jul 2003
    95 Skivic Cx HB
    Winchester, TN
    trust me, ive been in stereos 4 like 8 yrs, i know what im talkin about
    KoNEY
    so what wire your subs series/parralel for a 2 ohm load and run it in mono; if the amp can handle 1 ohm stereo it can handle 2 ohms mono
    Kingsport,TN
    Well, Crunch replied to my email. Turns out that the amp isnt even stable at 2 ohms bridged only 4 ohms bridged and 4 & 2 ohms stereo.. Damn, I need a new amp. More than likely i'll try it 2 ohms bridged and see what happens, If it dies on me... Oh well
    I'll probably try and find a JBL BP1200.1 ..Anyone know if those are good amps? I've seen them on Ebay at a decent price.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    a 1200.1 will fry that sub at 1 ohm.. over 2000 watts! get that dual 2 ohm and bridge it to 4 ohm.. then hook it 4 ohm mono to your crunch amp.. problem solved!
    Travis
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    The JBL 1200.1 puts out slightly LESS at 1 ohm than it does at 2 ohms... this is due to the limiting design they have in the circuitry. It IS stable at 1 ohm, though, and will put out roughly 1200 watts at 1 and 2 ohms.
    '92 Toyota Paseo
    St. Paul, MN
    My advice on your situation is this:
    If your amp puts out 800 watts bridged into 4 ohms, it will should work great for you. Just make your box big enough to use the wattage to the subs maximum efficiency.
    If you really want an amp that puts out ~1000 watts to the sub, I have a few suggestions, in order of preference:
    Tsunami 1100 DB - 1100 watts into 1 ohm, I have one, works very well, good quality, all around kick-ass amp. $235 + shipping from www.edesignaudio.com
    Lanzar Opti 1000.1 - 1000 watts into 1 ohm (not sure, maybe at 4), excellent quality and features, but you can only find them on eBay for a decent price, elsewhere online they are like $500, ebay is ~$200
    JBL 1200.1 - ~$230 on eBay and elsewhere, cheap power... that's about it, not great quality, but it gets the job done. Actually LOSES output over time if pushed to its limits all the time.
    Bloodlust's Avatar
    1989 LXi Coupe (SOLD), 1998 Accord EX
    Line Lexington, PA
    Definetely not stable at 1 ohm.
    Kingsport,TN
    Thank's for the "Heads up" on the JBL amp. I can tell you know your shit when it comes to Audio, Dave
    .. So i'll take your word on it and go with the Tsunami.
    Any class D amp loses its efficency when pushed to the limit all the time, whereas class a/b gains efficency at full power. The JBL 1200.1 has alot of power, but its isnt that stable and they have been known to start on fire (literally). For a good amp thats cheap, I like the Lanzar Vibe 1200d, puts out a ton of power, has nice x overs, and runs cool. It doesnt sound as clean as much more expensive amps or big big class A/B amps but most class Ds dont
  1. Looking for a good 2 channel amp that's 2 ohm stable...
    By TeKKnoTeKK in forum Interior & Exterior Care
    Last Post: 08-26-2002, 09:16 PM
