I dropped my transmission to replace my clutch today. Problem 1 is I could'nt get the release arm so I could remove the release/throwout bearing assembly. So since the bearing looked/felt good enough I got over that one and quit monkeying with it.
Problem 2 is that I cant get the freaking pilot shaft from the tranny to line up with the freakin clutch disk. And if you wanna I ask I DID center the disk using the tool then torqued the pressure plate on the flywheel. I think the root of the problem is that the teeth are not lining up. How is God's name do yo line those up if you cant even reach in and turn the shaft? I tried turning he driveshafts while wiggling the tranny on and no fuckin results. So the tranny is standing off about an inch+ from the engine. Another thing is I'm using 2 2-ton floor jacks to hold up the tranny. Made aligning to the engine a bitch.
I did had another person helping me too. God fuckin damn!![]()
Help me please. What are the tricks you guys use. Also bear in mind the car in on jackstands so its not that high. Give me anything you can think off.
I could be driving my fuckin car right now. All the howtos and manuals I printed. Went so well untill the beginning of the end.
