Results 1 to 11 of 11
Thread: Vent problem
    86'Honda Accord Lx-i
    Kansas City, MO
    Vent problem
    I was wonderin what the hell is wrong with my vents? It happened about 6 months ago and what happened was now when i try to turn my vents on the only fuckin setting they work on is high??? What the hell? So now it's either full blast vents or no vents. How can i fix this problem?
    Thanks alot,
    Chris
    *1986 Honda Accord Lx-i* 5-spd.
    17" Konig Maxxum Cam 178's wrapped in 205/40/ZR17 Kumho Ecsta Supras, Eibach Sportlines, Tokico struts, 92-95 civic custom short ram air intake, Magnaflow streetseries exhaust, 20% tint all around, Red/Black taillights, painted calipers and drums, hyperwhite corner bulbs, blue interior lights, Racing pedals, Carbon fiber shift knob
    2.0Si User accordlx's Avatar
    1988 Honda Accord LX, 2006 Honda Ridgeline RTL, Pontiac Sunfire Convertible, & 1979 Corvette
    Cincinnati/Columbus Ohio
    There is a resistor that controls the fan speeds. It is located somewhere inside the car near the fan itself on the fan housing. It should be held in place by either a clip or a couple of screws. It will look like a little access door from the outside but will look like it has springs on it when you take it out.
    LX User Einstein's Avatar
    88 Honda Accord LXi
    PA
    Yeah, the resistor is probably designed for the medium speeds, and is fully bypassed when you select hi. It's the resistor or the wires going to it.
    2003 Element Sunset Orange
    2002 S2000 Spa Yellow
    1999 CRV EX 4WD Auto White
    TRADED: 1988 Accord LXi Sedan Auto White/Maroon
    Had: 01 Civic EX Coupe, 00 3.2TL, 95 Integra GS-R Coupe, 92 Civic EX Sedan, 88 Legend Coupe LS, 88 CRX Si
    LXi User BoredRec's Avatar
    Nov 2001
    1988 Honda Accord LXi
    Las Vegas
    Yeah, and it's a pain in the ass to replace. Prepare to take out your glove box changing it.
    The reason why it works only on high is cuz the resistors are messed up, creating an open circuit. But when you put the setting on high it bypasses the resistors and sends (I think) battery voltage to the blower motor. That's why it only works on high.
    shepherd79's Avatar
    Falling Waters, WV USA
    you don't have to take your glove box apart. all you have to do is look under it. it is right behind blower motor. it has a plug, disconect it. remove two screws and take it out.
    you can eather solder it back together or you can get it from junk yard for almost nothing, i got mine for free.
    it takes less than an hour to replace it.
    10/Honda/Ridgeline
    NJ
    u guys are talking about the coil thingie right? usually it has depostis on it like mine did. carefully break it up with a needle nose pliers. they look like lime (calcium carbonate, not the one from my backyard).
    1988 Accord LXi hatchback
    ... they look like lime (calcium carbonate,
    As Julius from Pulp Fiction would say, "wooo check out the big brain on Brad!".
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    It is actually copper oxide, otherwise known as vertegris. That is what you get when wires corrode.
    10/Honda/Ridgeline
    NJ
    but mine was not corroded evenly. just the first two prongs towards the pass side had deposits on them. and when i broke the deposit off. the coil looked silvery???
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    Oh, looks like an old thread but here is my problem:
    Ok, I removed the resistors plate (2 screws) without removing the blower and replaced one of them (Low). Then i tried to put it back and guess what, couldn't put the 2 screws in, nothing to screw in! I reached through the hole and there is a loose metallic plate inside, i assume with threaded holes. I don't know if that plate was glued there and got loose or is designed to be loose. Wonder if anybody had same problem? I don't want to take blower out if can be done otherwise..
    BTW, don't take the so called LIME off, that's sort of cement for providing support for resistors. Without it they slack (due to current which heat them up) and short one others..
    10/Honda/Ridgeline
    NJ
    u probably turned the plate the other way around cause the plate is held down by a screw.
  1. vent controls in the vent, and near the drivers knee
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 01-09-2010, 10:08 AM
  2. What is the air vent cut off diaphram?
    By mephi in forum Carburetor Tech
    Last Post: 01-07-2009, 01:27 AM
  3. Short ram with vent or CAI?
    By maxsideburn in forum Performance
    Last Post: 03-31-2006, 07:50 PM
  4. need to vent
    By 89accord_lxi_coupe in forum Classic Honda Community Chat
    Last Post: 05-02-2005, 12:27 PM
  5. Vent Led's
    By Nate2310 in forum Interior & Exterior Care
    Last Post: 01-30-2003, 12:39 PM
