ok lets clear the gray area on our body kits.......
People have said that the Acura integra 1990 body kits will fit our cars. Well i did some extensive research. NOW... lets load down on our make model and kinds of our cars.
for one thing there are a few standards on all our cars. like the wheel base (between front and rear tires) are the same on all models. and width of the car are ALL THE SAME.
now the rear apron for our lovely h/b are annually 3in shorter than the coupe or 4 door sedan.
so lets lay the specs out on paper for our cars.....
wheelbase = 102.4in (front tire to back tire = where you put the sideskirts)
width = 66.7in wide (width of front apron, or rear apron)
now the front and rear tracks are different from h/b to coupe or sedan, because of the rear apron length.
OK so here is the specs of the 1990 integra
wheelbase = 100.4in (on the 3 door h/b) and 102.4 (on the 4 door sedan) ****hince use the 4 door for a better "direct fit"****
width = 67.5in (perfect match for our cars)
NOW the only problems i see is: the rear apron and the turnsignals sticking out to far, (and maybe the sideskirts if you ordered for a 3 door integra. which you could cut and extend those 2.4in with fiberglass)
NOTE ********* i have not tried this conversion yet. But i WILL MAKE IT WORK. i will have my bodykit in about 3 weeks. i will give a detailed description of my progress and detailed photos and a how to for my fellow accord users.....
we all kick ass.......
