Results 1 to 9 of 9
Thread: msd ignitions?
    86 si accord .... 5 speed :)
    Question msd ignitions?
    what exactley does it do...
    i know they give a higher spark to all cyls
    and im picking the components are High performance(leads etc)
    but does it do anything else?
    and is it worth the money... or is a fuel mapper a better investment?
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    Re: msd ignitions?
    Well it gives you a better combustion, better idle, better fuel MPG and gives you a bit torque and HP.
    But if your fuel mapper has to do with reprograming your computer, then do the computer first. I think that'll give you a better bang for the buck.
    http://vtecnos.tripod.com
    Member Since 7-9-01
    Miami, Florida
    Oh and an MSD will come in critical if you have Nitrous or Turbo. If you are Natural aspirated, a performance coil should do a good job for alot cheaper.
    Member Since 7-9-01
    1/2 JDM B18A DOHC CARB
    MD
    I like my MSD 6 AL. Provides good power throught out the RPM
    range.
    Carl
    ahh i c
    basically im gonna TRY and get nos but i am following the checklist put forth to me and slowly doing the basic upgrades
    pod, headers, 2.25 exhaust..larger tip
    then power n plugs
    and fuel system
    i can either try and get fuel mapper and high flow rail and pump
    or get all elctrics done
    and do those engine capacitors work? i can get one of those cheap supplies 11-16 volts solid
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    You really don't need a larger tip since the exhaust gas cools as it flows thru the pipe... maybe a 3" polished tip to cover the 2.25" pipe, just for appearance sake. you really don't need a Cat, Resornator, or muffler either. Since most of it is for emissions and noise control.
    I was looking for a nice long polished tip so I could lop off my muffler temporarily and just run a straight pipe. Then I would just reconnect the muffler with a larger pipe and clamp it back onto the exhaust.
    LOL you call it an air pod... K&N is the most common performance/replacement filter.
    Ask 88turboaccord about adjustable fuel pressure regulators and other efi parts he may have made...
    and what do you mean about engine capacitors??? like NOLOGY wires
    YEAH AIR POD :p
    HEHE Yeah kiwi lingo i spose over here we have all the jap pods as well like apexi hks and so forth...but k&n has 1,000,000 mile warranty
    the product is a jacobson accuvolt..
    i think basically its a 50 amp capacitor that you run inline with your power leads and you can dial in the required voltage(up to 16 volts) ...and it stays at that
    88 LX-i
    ellisville MO.
    careful with running a feul mapper. your car is most like tuned to run at 15.5:1 (most ecno), the most you could do is tune it tune 12:1 (most preformance). after 12:1 you are doing nothing but wasting gas. if you want to know what 12:1 will feel like disconnet your O2 sensors and your check engine light will come on. when the check engine light is on, the ecu runs the car rich to ensure that there will be no knocks.
    I’ll kill you with experience
    OH REALLY?
    I was thinking of basically getting one to get it tuned up and for if/when i get nitrous or bigger cams etc... i can tell the injectors to stay open longer and give some me some more gas :super:
    i may consider a full ecu controller if i go ahead with the major mods but at this stage im doing all the small things like intake etc
    im also doing my stereo so its a case of ten things on the go and nothing finished
    oh well
    P.S will i need to get better pistons and rebuild engine for N2O?
    or if i pass compression tests leave it at that?
