how do u set the right size for the speedometer, and the ft gauge on pauls gauges on photoshop 7?
photoshop 7 newest version with no adjust image option
thank you![]()
thank you![]()
the image is set to be the right size as long as u print at 300dpi.
just print out a copy on draft quality. i didnt have to change a thing, it just printed fine the first time.![]()
i took his off the site and modified them, i never downloaded them
if u took them off the site u downloaded them...
how did u modify them? (ie, just changed colors...) if u have PS then it should have guides which tell u the size of the document u are playing with..
WHAT HAPPENS WHEN U TRY TO PRINT THEM OUT ON REGULAR PAPER!!!
yes i did download them sorry, and then i put them in photoshop and changed the colors and text around, when i print its just small because its in photoshop.
how do i print in the right size out of photoshop 7
or if i paste into word how do i change the size>?
the speed is 10.00cm
f/t = 8.80
but how do i change that?>
thank you
in photoshop you should be able to make them print at 300dpi... if u do this... it "should" look right... i dunno.. i never had to mess with it... but why cant u go into image adjust???? that is where u need to go to specify the dpi of the project...
can u see the "rulers" around the image? they should indicate the size of it.. since u are printing a whole document it will be like 8"x10.5" or something. but still. u just need to know that its not gonna print out tiny.
tell you what. email me the file u are playing with, and i will see what i have to do to get it to print out the right size.
[email protected]
thanx man ill email it to u right now
hey bobba i just figured it out and got everything set up, u dont need to do them for me, do u like the gauges though? hehe
later broski-
