I was trying to think of how to get a bit more performance out of our motors without expensive engine re-working, and I was thinking about spark plugs and compression. Have any of you ever seen a marine surface-gap type plug? if we can find one that is the correct thread size and that extends into the combustion chamber to just about the same point as the electrode tip does on our normal plugs, then used an msd or other hi-intensity discharge ignition to fire it, I think it would give a nice little jump in compression because of the way a surface-gap plug is constructed, and would probably have better flame propogation too when using them with high-powered ignitions. What do you guys think? Is it worth a try?
