Results 1 to 18 of 18
Thread: 88 Lude S Seats in my 86 Accord S
    LXi User L3G10N's Avatar
    Princeville, Quebec
    Yeah finally, i've swap...... not my engine but my seats :super:
    The 88 Lude S seats are just perfect. If someone ask me to choose between Sparco or my 88lude seats, i definitly choose the Lude ones!
    The lateral support are adjustable and totally insane!
    Here are the pics!
    There is the little mods to fit 100% perfect the seats
    My 86 custom build thread
    Jul 2003
    87 Accord DX
    What did you do to get them to fit?
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Those are the same seats I got!!!!!!!!!! Mine are in mint condition. Hey how did you get them to fit? Do I need to use the old sliders ? Or start drilling holes to make them fit?
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    i have the same ones too.. but instead of two pins on teh head rest, its a solid bar thing
    Travis
    Mankato, Minnesota
    Umm.... Travis can you tell me what I would be the best way to put them in?
    -Mike
    NORTH BAY ONTARIO
    MSN man... ill tell you all about it
    Travis
    Princeville, Quebec
    it's simple if you have someone who can weld the inside slider., not the complete slide, just a small part. If you do it correctly, it's bolt on on the original bolt hole without any 2x4 like you DXhatchback
    For the slider belt side you have to cut the part who are bolting the back seat
    See, in red are the original accord slider with the part cuted out. You will need to remove the kind of metal spacer of the bolt too because the lude part, in blue, are soldered behind the original accord slider. The lude part will do a spacer, so if you don't want to get a inegal seat, you'll need to do this. The part in blue circle come from the original lude rail. You'll need to cut it at the bottom of the real to get the bigger part possible to weld it hard... if you don't want to get a cheap job who will broke when you'll hit something one day. So, weld the lude part behind the accord slider and you'll get this pics as result.
    The blue arrow show you where is the bolt who won't fit directly in the seat. You'll have to drill another hole in the seat just beside the original one to be able to fix the accord rail, only the part with 3 bolt, not all the slider.
    so, after doing all this, you can put the seat in the car and it will fit directly in the original bolt hole.
    For the plastic cover in the blue circle, you'll be able to put it back but you'll need a longer screw.
    if you have any question, you're welcome.
    I'll try to get better pics of the original slider without any mods and the slider after, so you'll be able get a better look to the job.
    NORTH BAY ONTARIO
    damn... i wonder if i could have just did that??? oh well... im gonna get some race seats anyway... if i even keep this car...
    Travis
    Princeville, Quebec
    keep it man, keep it, 86 hatch are soooo rare in good shape
    NORTH BAY ONTARIO
    well... i have an 86 hatch, and there are like 5 in town of 56k, BUT MINE IS DEFINETLY NOT IN GOOD SHAPE... pip's car on the other hand is beautiful... i just had a look at it this afternoon.. very nice car
    Travis
    carotman's Avatar
    Montreal South Shore
    Damn, I need to get some....
    I'll hit the junkyard tomorrow
    I need these parts!
    Princeville, Quebec
    :super:
    Mankato, Minnesota
    Alright so all I need to do is do some cutting and use the inner sliders from the stock seats and then solder the brakets together? Or do I need to weld them? You told me soldering last night on msn and now its welding so I'm not sure what I need to do. Thanks.
    Princeville, Quebec
    i don't know which exact word to use between solder and weld. But you can be sure that you need the stronger possible. So, check which one is the stronger and you'll get your answer.
    sorry for my poor english
    Mankato, Minnesota
    Oh it's perfectly fine. I would have to say weld b/c it is stronger. I can't want to put mine in. I'm buying my tool box tonight and it has a side cabinet with a bench vise on it so then I can work with stuff on it. I don't have a welder but I'm sure a student at the vo-tech can help me.
    Princeville, Quebec
    it will take 30minutes to get the same job than mine. Really simple
    Princeville, Quebec
    Mike will send me a few pics and i'll do a "how to" for the board.
    Idaho
    NICE seats, you should have vaccuumed and cleaned out your car before taking pictures though.
  1. Got me some Lude Si seats!
    By 86-lxi in forum Classic Honda Community Chat
    Last Post: 10-12-2010, 07:20 AM
  2. Anybody run 3G Lude Seats?
    By AccordEpicenter in forum Classic Honda Community Chat
    Last Post: 11-01-2004, 05:04 PM
  3. lude seats
    By AccordAddict in forum Interior & Exterior Care
    Last Post: 10-07-2004, 07:01 PM
  4. FS: Mint 89 Lude Si Seats and led spoiler from the same car!!
    By Mike's89AccordLX in forum Trading Post
    Last Post: 08-22-2003, 05:56 AM
  5. How to put on 88-89 lude seats.
    By Immeraufdemhund in forum 3geez Accords
    Last Post: 05-20-2003, 05:32 PM
