hey yall, how do I remove the black window trim on the outside, I gotta take it off so I can fix some rust holes, same with the Trunk Glass on the HATCHBACK.
1992 Tsi AWD
Status: Fixed.
WANTED ANY 3GEE IN FL!
I have heard most people just use a razor blade to clean it up.
nah, I need to REMOVE IT. To get to the Rust under it.
1992 Tsi AWD
Status: Fixed.
bump
1992 Tsi AWD
Status: Fixed.
Yes. A good razor blade would get most of it off, and leave about 1/6 of an inch on either sides. We had a thread that mentioned maybe heat gunning it off. But the paint and glass was an issue...
-Strugglebucket
-redaztec
DAYUM!
-2ndGenGuy
-MessyHonda
I think he's talking about the trim itself, not the plastic coating on it...
Or, if you're not, yeah... the razor blade method works good, just don't accidently scrape something you don't mean to and scream "FUC*!!!" lol
Im talkin bout the whole peace, not that black stuff.
1992 Tsi AWD
Status: Fixed.
Ah...rip off those corner pieces. Those are where the 4 trims meet. From there, just gentally pull it off...and when you need to reatach it, just use and adheasive. Now I haven't done this...so I don't know how risky it is.
-Strugglebucket
-redaztec
DAYUM!
-2ndGenGuy
-MessyHonda
adheasive, Like some kind of TAPE or glue, or something else that can fail later on, no thanks. I think there are clips, I dunno, but thanks every one.
1992 Tsi AWD
Status: Fixed.
anybody have some more recent experience with this? My window trim mouldings are peeling off and I do see how a razor could be used to pick it off. That would seem like a tedious process, how about removing the trim and using paint remover, media blast, or a small herd of mice to chew it off. I want to paint it, no chrome.. besides since it is chrome underneath why did they put a black plastic uv sensative coating on it?
I did a little of this on my 5th gen civic, that coating was relentless, all of it has to be removed because it does not take paint well at all.
if you guys are talking about the small window trim, you open your door and remove the two screws in the side, then GENTLY slide the trim (at the bottom of the window) towards the door. i say gently because if not you break the clips.
i'm looking at a new three m tape which is like trim attachment epoxy on a roll. those dam clips usually break no matter how careful you are and are very expensive to replace. most of mine are broken now. modern quality trim adhesives have the opposite problem of if you have to take the trim off later,good luck. they are nothing like the trim adhesives a lot of domestic car companies used in the eighties and early nineties. the ones that are missing trim now.
