Ok, I am pissed.This is probably the third or fourth time I have posted on my idle but I am just triple checking things.
I went to the post office and let the car run while I did my thing. It's about 70¡ here and I took about 30 min. When I get back to my car, the F***er is doing 3000 Rpms! I tap the gas and the B**** jumps to 4000!!! I am just like "Damn it! It is happening again!!!!!!"![]()
<Finishing story> So I shut it off and it takes like 7 seconds to spin down and then diesels like a Motha. I wait a little bit and quickly turn it on and slam it into reverse at the same time. Ca-Chunk! I get into gear and I get on the road. When I let off the brake it was idleing so fast it felt like I had the accelerator pushed down! When I came to a stop, it was idleing at 1500 Rpms in Gear!!! So I got home and decided to shut it off in gear and not have to deal with the high rpm shutdown/dieseling. Wrong! I shut it off in gear and it dieseled for at least 10 seconds!! It was just like "Sputter, Sputter, Sputter, etc, etc."</Finishing story>
<Real question>Is it my PCV valve? If I idle around it doesn't help but if I actually press the gas and drive around it gets better after a while; Like me pressing gas is making the valve open and close until it gets back to normal.
I already kind of checked for vacuum leaks but I couldn't find any.
Also, if I let the car sit for like 1-2 hours, it is back to normal and I can drive again.
Please I need some major help. I don't want to go through this again, and it seems to happen more often as it gets hot outside.![]()
