Okay since $1500 is not cheap enough for the tubo kit, I will sell just the turbo charge pipes/turbo header for $500.
The charge pipes has a flange for a gready BOV and the turbo manifold has a flange for a turbonetics deltagate wastegate (which you can make a plate for if you use a turbo with a built on wastegate.
Also the pipes are made for a intercooler (which you would have to provide.)
Hope this is cheap enough, I need to start getting rid of all this stuff.
