Results 1 to 25 of 30
Thread: how in gods name do i remove back seat
    gekko's Avatar
    88 Accord AeRodeck EXI, 77 chrysler Cordoba SS22 6.6l V8
    Norway
    how do i unhook those 2 clips under the back seat ?
    My Car
    Street Racing Scandinavian Style !!
    "If you feel in control. You're not going fast enough"
    Jan 2003
    1987 honda accord
    toronto ontario
    At the back of the seat there is a tab that is bolted down with a 10mm bolt undo that and you should just have to lift the back that you unbolted and the hooks up front of the seat will slide out. you might have to look alittle cause the seat sort of covers it. you also must get rid of the seat back first(you probably did this already)and thats all you have to do. Have fun peace.
    racer x
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    aww.. no red X? shitty... lol
    Travis
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Well stick your hands by the seat belt things (wheere your ass would be) and pull up the seat. (I have a 4 door and this is how I do it) Huh I guess I have never removed the back part before.
    Jan 2003
    1987 honda accord
    toronto ontario
    The bolt was probably just not there I to have a 4door and had a bolt holding my down.
    racer x
    WA State
    The first time I tried to take my backseat off I ran into the same problem, and realized there is a bolt you have to take off. Each end of the seat would pull way out, but something in the middle wasn't going to let it go. Eventually I got. But what a bitch.
    gekko's Avatar
    Norway
    yepp found it , i was not far away from just cuttin the seat up ...
    and it was so easy when i found it out
    Thanx:super:
    My Car
    Vinny's Avatar
    Aug 2003
    Here, not there
    I just pop the bottom up with a long screwdriver from the fron, then pop the bolt out
    Re: how in gods name do i remove back seat
    Quote Originally Posted by Vinny View Post
    too much popping going on there... looks like the cover on the seat back has to come off. Hatchback, then you get the bolt and lift up to unhook it from the front part of the seat.
    AZ
    roodoo, this thread is 8 years old lol...
    dead white and blue
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Hey at least I searched the query of back seat removal. Low and behold I found a bunch of dead threads with very few posts and incomplete info lolz
    Finally found a little bit enough to figure it out before I ripped it out like some people were talking about )
    Got gas leaking out on the exhaust by the tank.
    push down the middle of the back seat, you'll see the bolt, ten mm on a long extension and lift it up and off of the front hooks, takes about 30 seconds,it's probably the rubber hose from the vent line to the tank, you may have to lower the tank to reach those, I think there are several rubber hoses inaccessible from the ground
    AZ
    Omg old people are old.
    dead white and blue
    roodoo asked me earlier how to do this, so I'm answering his post
    May 2012
    central Ohio
    Can I get some clarification here? I'm trying to remove the back seat bottom on my 88 LX-i coupe. I found the 10MM bolt in the center of the seat by spreading apart the seat top and bottom with my hands so that I could see the bolt. I removed the bolt. Still, I can not get the seat out. Clearly, it's being held by two hooks in front, but is it also being held by something else?
    Do I have to remove the seat top? If so, why? And if so, how? The back/top pivots on a hinge at both ends, so how can it be removed?
    bridgewater.NS Canada
    Just roll the bottom of the seat ahead,then pop the hooks out of the slots in the floor.The back seat should have a bolt on each side by the seat belt mount,take those out and lift up on the seat back at the bottom.
    It's a coupe; one clip on the driver's side, one 10mm bolt in the middle and two hooks. You need to rotate the bottom half of the seat almost completely vertically and wriggle it out.
    DX User gtoman's Avatar
    Jun 2012
    1986 LX-i Hatch 5 speed, 2005 Pontiac GTO 6 speed, 96 Honda Civic EX 5 speed
    Raleigh, NC
    Is this thread really still alive or am I just seeing the ghost of 3geez past?
    Adam
    _________ _______
    fkin grave diggers!
    I saw some old names in there!
    on a sedan:
    there is a plastic clip on the fold down seat back hinge, I think it's on the driver's side, when you pull the clip out you can pull the seatback sideways and remove it from it's hinges. Then you remove the 10mm bolt from the middle and pull up the seat bottom from the back up and that will free the two front hooks
    Smile Re: how in gods name do i remove back seat
    Hey man,who you callin old.
    new guy dug up the thread because he had a question on this same issue instead of starting an entire new thread on something already answered
    LX User 247shuer247's Avatar
    Feb 2011
    1986 accord lx-i
    wow to remove the seat in my hatch there are no bolts literally just two clips and angled bar but i didnt need to remover bolts
    ''YOU MAY LOSE MONEY CHASING WOMEN BUT You will no doubt end up broke as a mothafucka chasing cars''
  1. How the hell to I remove the back seat...
    By Hash_man_Se_i in forum 3geez Accords
    Last Post: 11-17-2005, 11:25 PM
  2. My Big Gay Back Seat
    By 89AcCOrDmike in forum Interior & Exterior Care
    Last Post: 08-08-2004, 03:54 PM
  3. RSB, no back seat
    By BLck89accord in forum Performance
    Last Post: 03-23-2003, 01:00 PM
  4. Replies: 4
    Last Post: 09-18-2002, 10:01 PM
  5. cant pull back of back seat out
    By 89blackdx in forum Interior & Exterior Care
    Last Post: 08-14-2002, 08:54 AM
