Results 1 to 17 of 17
Thread: Single cam screamer / D-series idea
    1989 SEi 4dr (H22A soon?)
    In tha desert!
    Lightbulb Single cam screamer / D-series idea
    Call me crazy... go ahead...
    Now that I'm in the terminal stages of shoehorning an H22 into my 3G, I'm considering the use of a SMALLER ENGINE in the next project car.
    So, the idea is to use an abandoned D15 or D16 engine (from older Civics/Tegs), turbocharged, to make up the heart of a potent 3G toy car.
    Buy D15. Do rebuild, including lower compression pistons (8.5:1? 8.0:1?) and stout rings. Maybe use some reinforcement on the cylinder walls... then add a Garret T25 from an SR20DET. Electronics are a bit of a mystery. Probably Hondata if money's not an object, modified stock computer with some fpr tricks if it is....
    This type of configuration reportedly makes 170whp @ 6-7psi. With the 8.5:1 cr and a different turbo, who's to say that 250whp is not possible? I think it is. At only 12psi? Hmm...
    There's a few production cars rotting in junkyards these days with Mitsu turbos just begging to be put to good use.
    And, the D-series is SMALL. It will FIT inside the engine compartment without doing 40 hours of BANGING, CUTTING, and WELDING!
    It's an idea.
    Engineer by profession, writer by practice, mechanic by necessity, martial artist by design.
    burgundy 86 honda accord/ brown 89 chevy caprice wagon
    im pounding oin mustang gts likes flys with a a20a.
    WWW.ACCORDCENTRAL.COM
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    And by "screamer" you mean screaming for help because you are being ass-raped, correct? :lol
    ~<+045+ygH05+>~
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    hahaha man...first off....i wanna see pics of this allegged h22 swap...im not calling BS..but i wanna see 3 pennies. its sooo explensive and talked about by everyone. a few people are attempting it..and they provided pics. not to be an asshole...jsut dont go saying your trying the most expensive, exstensive and difficult swap without proof to back yourself up.
    secondly....d series suck man. they arent bad...i mean honda puts a lot of efforts into all their engines..but they dont have great pick up and a b series would do you just fine for your car.
    -Travis-
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    buy seans A20 Turbo kit.!!!!!!
    I think he said he's runnin 6-8psi using a Garrett T03 and beating 'stangs all over the place.
    98 Av6 3oh
    Sacramento, CA
    wasnt justin [88turboaccord] selling his too?
    yeah a turbo'd a series or b series would be less work and just as good out put as any d.
    -Travis-
    a pile of lawn ornaments
    Newtown, CT
    rick, I'm with the other guys on this one too. Basically what you explained you want to do is take a relatively "aftermarket-abandonned" motor, add a turbo, and pop it into the 3G. I really like the idea, it's a great concept. But, what's the difference between doing that, and just doing all the work mentioned to the original A20A. That'll save you the trouble of the $$ to get the D in, and give you the extra 1/2 liter of displacement to stick with the A20.
    -Mark D.
    87 Lxi Hatch<-Blown Up!! 96 civic coupe
    Hot, Sweaty Florida
    I would turbo a fully built Gsr moter or a b16!!! My buddy has an integra that pushes about 310 at the wheels with 9 lbs of boost!!! He runs 11.9 with @ 10-15 lbs
    Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
    blah b series. junk junk junk junk junk junk junk
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    A series w/ Sean's turbo setup should yeild the same hp as the D series, plus the cast iron black of the A series should handle more torque than the aluminum block of the D series.
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
    Hot, Sweaty Florida
    B16 and B18 are a hell of alot better than the B20!!!! Hell, If it easier i wood be doing the H22!!! That moter can kick some serious ass!!! Just depends on what your doing!! Anything can be fast!! Even building an A20 for an all moter setup!!
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    If you're so hell bent on H22, get yourself a 4 or 5g and save yourself the headache.
    Nothin' 2 Old Racing
    All MOTOR
    2
    0
    98 Av6 3oh
    Sacramento, CA
    will said mike
    -Travis-
    10/Honda/Ridgeline
    NJ
    310hp with 9lbs of boost. What kinda motor are we tlakin about with what kinda compression?
    A series w/ Sean's turbo setup should yeild the same hp as the D series, plus the cast iron black of the A series should handle more torque than the aluminum block of the D series - Dibbie
    The A series having a much larger Displacement than a D-series, no way the D series makes the same hp as Sean's turbo set up on a A-series. besides, ur torque handling is on the tranny not the block. The block means how much boost u can handle (speaking on the grounds of turbo)
    Jun 2001
    Boston MA
    a nice d16z6 with a little work will work wonders over the a20a with a lil work. i know, ive built a couple of nice d series engines. the d16z6 is the best and they are easy and cheep and have a lot more aftermarket suport than the a20a
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    In tha desert!
    Cool
    Basically, the D-series sounds good because:
    1. It's a bit smaller (although smaller displacement)
    2. You may be able to find more, or get 1 cheaper than A20 (they're newer)
    3. As for claims that the D-series handles more boost or makes more horsepower at a given level of boost than the A20... I haven't built any myself, and concrete judgement on the subject shall be considered heresay until someone rips BOTH of these built engines apart and explains why one performs better/why both have the same performance.
    Just curious myself what a boosted, D-series powered 3G could do/drive like.
    Hey, I was curious about the H22A and look what happened...
    http://www.geocities.com/rick_spiff/car/index.html
    (need to update--new pics, THE ENGINE IS ACTUALLY MOUNTED INTO THE CAR, and she's been moved out of the shop into the in-law's backyard awaiting the 'finishing touches')
    And for the love of Pete, if anyone can tell me what the wire labeled "Electrical Load Detector" goes to, it'll help this engine get running that much quicker.
    ~out
  1. Worlds fastest single cam!!
    By adams86lxi in forum Classic Honda Pics & Videos
    Last Post: 07-24-2006, 03:38 PM
  2. Replies: 40
    Last Post: 12-03-2005, 05:33 PM
  3. running single o2 sensor q
    By anchovies in forum EFI Tech
    Last Post: 10-05-2004, 03:17 AM
  4. jdm 2.0 a20 single carb engine for sale
    By sniper556mm in forum Trading Post
    Last Post: 02-02-2004, 09:05 PM
  5. single winsheild wiper
    By lightbulblxi in forum Interior & Exterior Care
    Last Post: 09-09-2003, 08:08 PM
