I really need some help on this one:
(89 Accord LX, Carb, AT, 196000 km)
My car has a really rough idle, when warm or cold. It's worse in gear, but it also does it in park. I know the rough idle is definately caused by a miss on cylinder 3.
This is what we have done:
- Checked timing and cleaned/gapped all plugs.
- Disconnected plug wires, one by one. This affected the idle on all cylinders except #3.
- Switched plug leads between #3 and #4, still missed on 3.
- Switched plugs between 3 and 4, still missed on 3. BTW, There was nothing visibly wrong with the plug from 3, same colour, no mechanical damage.
(Now we are getting really worried)
- Performed a compression test. All cylinders were even and within a good range (Can't remember the actual reading)
- Removed the valve cover and inspected the cam lobes, all the valves were opening and closing properly and the clearances were all within spec.
(So now we know there is nothing majorly wrong, like cracked head or bent valve)
-Went back to suspecting the distributor cap, removed it, ispected it, looked fine. Then is zapped the hell out of my girlfriend's dad after we put it back on.
(Aha, now we KNOW it's the cap leaking)
-Brought a new cap and rotor, idle/miss problem is still there. Plug lead removal test still points to cylinder 3.
So the question is: What else is there that can cause only cylinder 3 to miss?
If it was the ignitor, the coil, or something in the fuel system, wouldn't it affect ALL cylinders randomly?
Update: Replaced the PCV valve, the problem is a little better, but it didn't make a big difference.
