Results 1 to 5 of 5
Thread: Shaking
    LXi User Mattphi's Avatar
    Jul 2003
    88' Accord LXI
    Jax, FL
    Arrow Shaking
    Whenever my car is stopped it starts shaking, sometimes bad and sometimes not too bad. Whenever i put it in neutral it stops. It seems that in the morning it doesnt do it as bad, maybe because its cooler outside? i have no idea, a friend told me that it the brakes but i dont know. Can someone help me out, thanks
    -Matt :pimp:
    shepherd79's Avatar
    Falling Waters, WV USA
    make sure your Air filter is clean.
    clean your TB.
    Jul 2003
    88' Accord LXI
    Jax, FL
    yea i noticed that it also does it when the AC is on, ill make sure to clean it
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    vacuum leak
    ...brake booster or somewhere else on the manifold... possibly the PCV Valve.
    2.0Si User zero.counter's Avatar
    2006 Nissan 350z
    Does school count?
    This problem mirrors my own in the past, hard idle, especially when I would engage the A/C. It was an electrical issue which I fixed by:
    a)replacing my shot battery
    b)cleaning the terminal plugs
    c)installing a thicker AWG. cable for the engine ground
    d)replaced a bad alternator
    Oh and prior to that, I had a faulty fuel pump causing the car to sputter erradically until it just died. The electrical system was draining so bad that power actually was sppread so thin acroos the other components, causing intermittent failures. I tested my theory by using a multimeter and plugging directly into the fise box for every individual item and found low voltages.
    That corrected my problem, just a suggestion though, and may not necessarily alleviate your own issue.
    natsugusa ya
    tsuwamono domo ga
    yume no ato
  1. shaking
    By 3rdgeneration in forum EFI Tech
    Last Post: 08-17-2012, 08:21 PM
  2. 88 lx-i pulling and shaking
    By HondaMan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-09-2006, 10:42 AM
  3. Vigorously shaking!
    By 88LX-iSedan in forum 3geez Accords
    Last Post: 10-13-2003, 01:17 PM
  4. Shaking
    By Janiel in forum 3geez Accords
    Last Post: 05-13-2003, 10:42 AM
  5. Shaking Wheel
    By inflikti0n in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-20-2003, 10:56 AM
