Results 1 to 25 of 36
Thread: 87 keihin 2bbl rebuild
    Jun 2002
    87 Accord DX Hatchback 5 Speed
    Cocoa Beach, Fl.
    OK, hello to everyone. My first post, I found the board this morning and have been reading alot. I bought a 87 Accord Hatchback DX a month ago. It's a fairly good car, but I bought it knowing a carb problem (cold start and poor idle) existed. I'm looking at a rebuild and want to ask if there is anything on the net yet explaining the steps for the 2bbl Keihin. First off, who offers the best (most complete) rebuild kit? Is the float seperate?
    Where to get the float? Stuff like that. I looked at buying a remanufactured unit from Foriegn Carb for $249 and Holley for
    $329. I went and pulled a carb from a recent totalled 87 for $50
    and now need info on kits, or if someone has a tip on a good rebuilding service that is $150 - $200 for a complete rebuild worth a shake I'd like to hear about that also. Another thing, I've rent space on a good server in Dallas and can hook up interested parties for low prices if anyone one needs web space. Anyway, damn glad I found this board, thanks for any tips.
    Oct 2001
    87 Accord EX , 5spd , Manual
    welcome !
    instead of rebuilding the carb you can get a weber carb ! and you'll gain performance too !
    MIKE
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    Keep reading! There are many other things I would try before attempting a carb rebuild on a 3g I just bought. I would try a full tune up, distributor cap/rotor, set ignition timing, wires, o2 sensor, pcv valve, etc. Most of these items can cause bad starting/idle problems.
    If these things don't help at all, it would probably will need them anyway at its age!
    Jun 2002
    Cocoa Beach, Fl.
    I've spent time with the car isolating (I think) the problem. At present a 1-2 second burst of starting fluid spray and the car starts immediately, goes to 2 grand fast idle and drops when warm. This tells me accelerator pump (which interestingly enough does not squirt that much when tested by operating throttle linkage). I know for a fact the accelerator pump is screwed. And the Weber carb while seemingly great idea, kinda screws me on the vacuum situation, as I've already checked that out and from what I've been told the stock vacuum connections are tossed. So, can someone explain the loss of vacuum to alot of systems and how that is overcome? Anyway, I appreciate the upfront responses but I'd like to hear about what I asked about (if possible) and get some recommendations on best kits and possible rebuilders. Thanks.
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    Why not drop that totalled 87's carb right in? Just asking!
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    This might be a more useful response:
    http://www.hondaautomotiveparts.com/...ry5=CARBURETOR
    Jun 2002
    Cocoa Beach, Fl.
    basically because of the hassle. you just don't *drop* these carbs in. when I install it I only wanna do it once if at all possible, hence rebuild the sucker now and know it's right instead of putting it in and finding out it is not right. does that make sense?
    seems perfectly clear to me, but I'm an old burnout.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Well I tried to buy the rebuild kits but they would always send me the wrong kit... it was either from the civic or prelude carbs... so i ended up making the gaskets myself and replacing the o-rings in the float adjustment screw... oh make sure the tension spring on the accelerator pump it tight... i had to buy a new spring because the old one would cause a delay from the time i pressed the gas to the time the accelerator plunger started to move.
    I got most of the spare parts from various hardware stores and the gasket material from the auto store.
    If you can find the kit then it will be a whole lot easier... but I won't be able to give you much instruction on which o-ring goes where and such.
    a few things to note:
    The float adjustment screw has to be turned inwards to be removed (Clockwise)... remove the float first so the screw can be removed.
    The float screw loves to leak gas once you fiddle with it, so you better have the kit or spare o-rings handy.
    the carb cannot be turned upside down... or esle it wont work.
    A20A1's Avatar
    Sep 2001
    hmm you could convert to mechanical seconndary... with the spare A/C idle boots parts.
    don't rebuild or buy a rebuild carb either, not worth the expense. More likely your troubles are related to all the vacuum-operated components the carb runs on and getting a weber will allow you to remove them all for the price of a factory rebuid carb
    just hope you don't have to get smogged
    Eric
    1/2 JDM B18A DOHC CARB
    MD
    Originally posted by ACCORD EX
    welcome !
    MIKE
    I second that!!!!
    VRRROOOOOOOOOOOOM!
    Carl
    Jun 2002
    Cocoa Beach, Fl.
    well, all the aftermarket carb hype aside, I've decided to do a stock Keihin 2bbl rebuild and plan to document via photo and text the procedure. I guess I'm old fashioned. Anyway I'm in need of assistance for the project, which will be on my site, and if response is good from this one I'll donate the write-up for a
    howto here. It's a valid undertaking. Any takers for helping?
    Right now I need some serious knowledge of the various vacuum ports, pots, and linkage. Thanks.
    Oct 2001
    check these 2 links about carbs one is done by POS CARB adn the other by me !
    https://www.3geez.com/showthread.php?s=&threadid=74
    https://www.3geez.com/showthread.php?s=&threadid=117
    enjoy
    MIKE
    shepherd79's Avatar
    Falling Waters, WV USA
    Welcome to the board.
    well, it sounds like your fuel pump doesn't pump the fuel or ot does and it is not enough. if you have Autozone where you live, go there and see if you can load the fuel pressure gauge. you should be able to tell, if the presure is not stable it is your pump.
    on the top of this, your carb is not starting because it needs a little tune up. first try to find the idle crew it is on the back, big black thing. try turning clockwise. this should increase the RMP when it idles. just remember how many time you turn, so you could go back to normal position.
    if turning the crew didn't help see if you can find a vacuum leak. it is common on carb engines.
    another thing you should consider is changing fuel filters. there are two of them. one under the left rear wheel. and the other one next to the carb. they could be so dirty. that they don't allow any fuel to go through.
    you should be able to get filters under $10 in autozone or anyother parts store.
    but try to do the tune up and stuff like that.
    if still want to rebuild carb. you can get a kit from autozone for like $30-40 it took me 1 hour to do this. it has every gasket and o-rings. it even comes with manual. when you gonna do it. do not touch the mixture screw. it is the one on the bottom of the carb sealed with a metall plug. it is bitch to addjust it.
    i think this all i have.
    i've been playing with Keihin carb since i got it.
    Jun 2002
    Cocoa Beach, Fl.
    well here is what I have so far.
    http://87accord.com/carbpage.html
    if any of you can fill in some info that would help
    I think my email [email protected] is working
    if not [email protected] is. Thanks for any help.
    I apologize to non-broadband people, I'll optomize
    the images and content later.
    shepherd79's Avatar
    you are preatty much set man.
    just start working from the top to the bottom.
    as i said don't take out mixture screw out. you will have a very hard time adjusting back to where it was.
    on the choke part, where it says take it apart, i didn't do it. so i don't know how. but the rest of them are pready easy.
    Oct 2001
    pretty good man ! good work ! :super: :super:
    MIKE
    A20A1's Avatar
    Sep 2001
    Front side of carb
    A.Idle Control Diaphragm (High vaccum lowers idle. Low vaccum increases idle)
    B.Throttle cable bracket
    C.Choke opener diaphragm
    D.vacuum port (Controls Vaccum Secondary Diaphragm)
    E.vacuum port(Air Jet Controller - Letter "?")
    F.Vaccum Secondary Diaphragm (Opens secondary Barrel)
    G.Float bowl vent Pipe
    A20A1's Avatar
    Sep 2001
    Rear side of carb
    A.a/c idle boost vacuum port
    B.a/c idle boost vacuum diaphragm
    C.Accelerator pump linkage
    D.Vacuum port (Power Valve - Connects to Manifold Vaccum)
    E.Vacuum port (To Air Jet Controller - Letter "?")
    F.Coolant hose (Carb base plate heater)
    G.vacuum port (?)
    H.Idle fuel/air mixture screw
    I.Vacuum port (?)
    J.Ignition Fuel shutoff solenoid
    K.Vacuum port (To Air Jet Controller - Letter "?")
    L.Vent port (Fuel - To charchol Canister)
    M.Fast idle adjust screw
    N.Throttle Stop Screw (Sets primary throttle plate opening)
    O.Choke unloader cover
    Jun 2002
    Cocoa Beach, Fl.
    thanks A20A1. I have updated the page. I'm gonna get all
    the vacuum hose numbers for the ports when I do the install and that may help in identifying the operational nature of each port.
    I've also got a writeup on the actual rebuild with photos in progress and will try to get that online by next weekend. The complete howto should then be available for this forum then if the admin wants it. The project still needs work, so anyone reading take a look and see if ya got anything to add. Thanks.
    A20A1's Avatar
    Sep 2001
    On letters "G" and "I", I put (Carb throttle / Manifold vacuum) cause the vacuum port exits into the primary barrel but since it's below the throttle plate, as the throttle opens. The port is considered manifold vacuum.
    The letters of the Air Jet controller are: A,B,& C. I'm still not sure which one goes where...
    Rear side of carb
    C.accelerator pump linkage
    D.vacuum port (power valve - connects to manifold vacuum)
    E.vacuum port (to air jet controller - letter "?")
    F.coolant hose (carb base plate heater)
    G.vacuum port (primary carb throttle / manifold vacuum)
    H.idle fuel/air mixture screw
    I.vacuum port (primary carb throttle / manifold vacuum)
    J.fuel shutoff solenoid
    K.vacuum port (to air jet controller - letter "?")
    On Letter "L" I made a mistake
    L.vacuum port ( Venturi vacuum to charcoal canister)
    M.fast idle adjust screw
    N.throttle stop screw (sets primary throttle plate opening)
    O.choke unloader cover
    A20A1's Avatar
    Sep 2001
    Left side of carb
    A.float bowl vent tube
    B.vacuum port (float bowl vent valve diaphragm)
    C.float fuel level view window
    D.secondary vacuum diaphragm linkage to secondary throttle
    E.main jet cover
    F.a/c idle boost screw
    G.fuel line port (1/4")
    H.vacuum port (primary venturi vacuum)
    I.accelerator pump linkage
    J.vacuum diaphragm port, a/c idle boost(need info)
    A20A1's Avatar
    Sep 2001
    I changed the word IDLE to THROTTLE in letter A.
    Check for other changes.
    Front side of carb
    A.Idle Control Diaphragm (High manifold vacuum lowers throttle. Low manifold vacuum increases throttle)
    B.throttle cable bracket
    C.choke opener diaphragm
    D.vacuum port (primary and secondary venturi vacuum: Controls Secondary vaccum diaphragm)
    E.vacuum port, Air jet controller, letter ?
    F.vacuum secondary diaphragm (opens secondary throttle plate)
    G.float bowl vent tube
    I've bought that kit before, it is my honest opinion that it is totally not worth the hassle of rebuilding these carbs because they are so fragile and complex, plus I guarantee you'll lose something lol
    I have pics of my rebuild if you want but I must warn you I can't tell you if it was a success because I turned it upside-down during the rebuild (instant death for these carbs!!!)
    Eric
    Jun 2002
    Cocoa Beach, Fl.
    well, POS carb, I can't see the problem of inverting the carb
    during rebuild, in fact you need to invert the bowl cover to get
    the float out. And in order to set the float during re-assembly you invert the cover, then go diagonally. The throttle body can be inverted, no problem, and the bowl assembly too. The inverting thing as far as I know is in fully assembled there is a chance of a stuck float. What exactly causes instant death when inverting a float cover, or throttle body, or bowl assembly?
  1. holley 350 2bbl carb
    By hondaman1986 in forum Carburetor Tech
    Last Post: 02-19-2007, 01:41 PM
  2. Hey need big help ( Blow Through 2bbl Keihin Carb )
    By lilneedle in forum Carburetor Tech
    Last Post: 08-19-2006, 09:39 PM
  3. MODIFICATION , STOCK 2BBL KEIHIN CARBURETOR
    By s0crates82 in forum Restoration & Custom Fabrication
    Last Post: 07-23-2005, 04:39 AM
  4. [Engine & Transmission] Running Keihin 2bbl Carburetor without emissions or electronic contorls.
    By ACCORD EX in forum How To
    Last Post: 11-24-2004, 11:38 PM
  5. nos on lx 2bbl.
    By 89ackerd in forum Performance
    Last Post: 01-28-2004, 11:09 AM
