Results 1 to 6 of 6
Thread: question for amp guys
    Banned Neuspeed007's Avatar
    Oct 2002
    1995 Civic Ex
    BOISE IDAHO
    can i take apart the amp? and see inside of it. is there any fuses in there that maybe i blew... i was just driving around with some bump bump then it stopped and there was no bump, im clueless
    Jun 2002
    1988 HONDA ACCORD LX
    from ALASKA stationed in Korea
    yes you can open it, it might void warranty though. the best thing to do now is to smell the amp (sounds stupid i know). Does it smell like burnt solder? then you might have fried the amp. otherwise I still think amp is good, and to troubleshoot more.
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    What kind of amp do you have? and If it says that if you open it, the warranty is void, and you still have warranty left, then send it in to get fixed.
    May 2003
    88 Accord LX 88 Accord LXi
    Do you still have power to the amp? Some amps might have fuses inside, some might have external fuses. Like others have suggested, if it's still under warrenty be careful not to void. Also check the ground is good. Make sure all connections are tight.
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    I agree with Mac, make sure you check all the outer things first, before you try to open up the amp (even though I highly doubt opening the amp will allow you to fix your problem without doing work on the circuits/transformer/caps/etc).
    Check the fuse on the power line, the fuse on the amp (if it has one), the power wire connection to the amp, the ground, the speaker wires, inside the box to see if the wires fell off the subs, RCA cables still secure in place, etc...
    Were there any noises or smells accompanied by the "loss of bump" or did it just all of a sudden stop?
    Jun 2002
    Isn't that what I have been saying the whole time? hahahaha
  1. question for you hi-mod guys...
    By wrxdriver99 in forum 3geez Accords
    Last Post: 04-19-2007, 05:22 PM
  2. another vr question, sorry guys
    By cody509 in forum Carburetor Tech
    Last Post: 09-15-2005, 12:57 AM
  3. Quick Question Guys....
    By XxDark_AccordxX in forum Interior & Exterior Care
    Last Post: 02-06-2004, 03:02 PM
  4. question for u guys...
    By bobsaccord in forum Classic Honda Community Chat
    Last Post: 12-01-2003, 11:53 PM
  5. Sad question for you guys
    By hondamanlxi in forum Classic Honda Community Chat
    Last Post: 07-15-2002, 03:05 PM
