Results 1 to 8 of 8
Thread: ac compressor, romoval without loss of freon?
    Jul 2003
    i have a fully working ac compressor on my 89 engine, i am swapping in an 86 engine. i was wondering if there is a way to swap the ac compressor without the loss of any freon? or if there is a way to drain and return freon once the swap is complete?
    AZmike's Avatar
    Tucson, Arizona
    Is there a reason you can't just remove the compressor from the old engine and reattach it to the new one without opening the system up?
    Mike
    May 2003
    88 Accord LX 88 Accord LXi
    No not that I can think of. In order to change compressor you will have to disconnect the lines. Not worth even trying. It is also not good to vent freon into air. It is also illegal.
    Best bet: find someone who can recover your freon and recharge when you are ready.
    Also whenever you open a A/C line it is highly suggested that you change your drier. After you change the drier and compressor you should have the system vacuumed. The longer you vacuum the better. System vacuuming is to remove moisture. Moisture in an A/C system will eventually do damage to system. After a good vacuum recharge the system.
    Jul 2003
    thanks for the information all, i guess ill have to actually spend some more money on this, i bue itll be cheaper than recharging from scratch.
    AZmike's Avatar
    Tucson, Arizona
    I still don't see why you can't use the same AC compressor on the new engine and leave it full of freon the whole time that you're working on it.
    Mike
    PhydeauX's Avatar
    Eastern Penna
    Assuming you're putting the 86 engine into the 89 just unbolt it from the old engine, don't disconnect any lines, and tie it up out of the way. Swap the engine and bolt the ac back on.
    andy
    May 2003
    Yep, you are absolutely right. I was definately mixed up. If you are putting an engine into the car with the good A/C then do exactly what PhydeauX and AZmike said and you should be fine. Sorry about the mix up.
    Jul 2003
    thats great! thanks
  1. RED TEK 12a replacement for R 12 Freon
    By StrobeWylan in forum 3geez Accords
    Last Post: 02-18-2010, 03:06 AM
  2. Replies: 7
    Last Post: 03-23-2006, 08:22 AM
  3. Sucking out some freon from a friend's car
    By superdesi in forum 3geez Accords
    Last Post: 08-17-2005, 05:58 PM
  4. freon in the eyes
    By Tref_LXI in forum 3geez Accords
    Last Post: 04-13-2003, 08:44 AM
  5. a.c freon drainer?
    Last Post: 08-25-2002, 02:42 PM
