Results 1 to 11 of 11
Thread: cylinder head swap
    accord exi '88, A20A4
    RO
    cylinder head swap
    hi guys,
    i'm just about to swap the cylinder head (200.000 km...sounds like a diesel) to a 100.000 km one. is there anything particular i should consider when performing the swap (besides the classical cylinder alignment...etc...)?...was thinking to mark all hoses/wires on the intake mainfold, and leave it on the head until i've removed the head completely...(looks pretty hard to get to those bolts behind hte engine)......or is there any other (easier) way to do it?
    ps...
    i think the engine i have is a A20A4...if that makes any difference
    peace!
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    your about ready to swap cylanders.......and you arent even sure what engine you have?
    are you sure your ready to do this?!?!?
    -Travis-
    RO
    ...sorry...my mistake...
    i-m not sure if the european engines have the same code as in US. What i have now is a head for exactly the same engine as i have in my car now. According to the honda database here, the engine i have is an A20A4. That's why i wasn't sure if i could provide you the correct info...
    peace!
    1988starter
    Guest
    Get an OEm head gasket from the dealer no aftermarket also check both cams and make sure to use the one that has less pitts and scratches.
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    just mark anything you have to remove, hoses etc...
    like was mentioned use OEM headgasket
    uhhhmm.. While the head is off, check pistons condition, cyinder wall's, cam condition, etc.. etc..
    And torque everything to spec when re-instialling
    RO
    thank's guys...i'll do that..
    i've allready bought oem gaskets (all of them)...and the 'new' head i got, is complete...with cam and everything (that's why i replace it...my camshaft is gone...full of scratches)
    my biggest concern is how to remove the intake manifold...so i'll try to remove it after removing the head....(can not imagine how to get to the bolts otherwise)
    peace!
    DX User pedrosa's Avatar
    Jan 2003
    accord 20i 16 v b20a2
    canary islands
    i think is better if you pay an specialist, this is dificult job to first time
    up the irons
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    Its easy man....find a head that fits on your engine. Set it to TDC. Mark every wire and plug and hose with a piece of tape and a number and then write about that number in a little note book so you know where everything goes!
    Take off the VC. Take out the head bolts....take the head off....put a new head gasket on....put the new head on...timing belt....check timing.....bolt it up.....coolant....new oil....done!
    RO
    well...i did the same job on a couple of fords...and an opel i think...and it was not a big deal at all...however, i never did it on a honda....the biggest difference, as i can see, is that there is a lot less space arround the engine here
    but i'll give it a shot anyway
    thank's
    peace!
    RO
    ok...it's done!
    runs quiet like a fish now
    Now, according to haynes manual, the cylinder head bolts have to be tightened in two steps (to 30Nm and to 68Nm)..and that's it...
    According to the instructions that followed the gasket, they have to be tightened in 4 steps:
    1. to 30Nm....
    2. to 70Nm
    3. to 70 Nm and hot engine (90degrees (Celsius))...
    4. to 70 Nm and 90degrees (Celsius) after some driving
    i did a sort of a mixture....the first 3 steps. Do i have to do it again after driving?
    cheers!
    peace!
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    Yes. Bolts have a tendency to work and warm up/cool down, and work loose. Just pull the VC and do them, not that hard.
  1. cylinder head
    By 88lxi-shortram in forum Wanted
    Last Post: 08-10-2010, 06:19 AM
  2. Rebuilt 2.0 Honda Cylinder Head Accord W/ Head Set
    By 88accordSF in forum 3geez Accords
    Last Post: 04-16-2007, 07:36 PM
  3. cylinder head tdc?
    By 86lxiricer in forum 3geez Accords
    Last Post: 05-03-2005, 11:43 PM
  4. efi and p&p cylinder head swap started
    By nappyroots827 in forum Performance
    Last Post: 10-30-2004, 07:19 PM
  5. New cylinder head
    By ssophab in forum Performance
    Last Post: 11-03-2003, 02:25 AM
