I need a camber kit, I think that some of them can fo up to 2.25 degrees??? I would need that one.
thanks
thanks
I need these parts!
Just use the prelude arms. If that doesnt give you enough adjustment, Ingalls makes good ones. Justin had em on his accord i believe. There is another company that makes them but i forget the name.
Are you putting it on your car?
Nothin' 2 Old Racing
i heard someone was using prelude arms and camber kit for the front.
you only need to use the upper A arms. They are adjustable stock. I'm not sure to how many degrees though.
I think it's only .5 degrees for the prelude arms... I need more (at LEAST 1.5 but I want a bit more....)
I no one has used ones... I'll get some brand new ones.... that's not a problem...
I need these parts!
I have some lude arms, they can be modified for extra camber. Send an offer if you're interested, with or without new balljoints.
Eric
i don't think prelude arms .5 deg.
i had 1.5 camber kit and it wasn't enough for me. so i went and got prelude arms. well i didn't see any diff.
prelude is more like 1.2 1.5 deg.
I want ooonnnnnneeeee :~(
I need these parts!
I can get you an Ingalls camber kit. It'll probably cost about 140-150 shipped for both sides. PM me if you're interested. I can also get Eibach kits, but they're a little more ($200+s/h) and i dont know if they have as much adjustment.
I really liked the Ingall's kit. Installation was a snap. I only bought one to correct a factory camber problem. Once the adjustment is set you never have to touch it again.
Using the Prelude arms sounds a bit cheaper, but once you go through the trouble of going to a junk yard, replacing the ball joints, playing with washers, etc. it doesn't seem like such a good deal to me.
nx racer do they make camber kits for rear too?
i might need a real kit, my prelude arms just arent cutting it anymore
just get a longer bolt for the back. I've heard of the back Ingalls kits breaking.........
ok so for 150 ish i can get an adjustable ingalls kit that will do more than my lude arms? i will be in touch after my next check![]()
