Results 1 to 18 of 18
Thread: stupid oil pan
    88fasthatch's Avatar
    88 accord dx hatch
    santa rosa, ca
    Angry stupid oil pan
    I would recommend that any trying to replace their own, stop and take it to a shop. I took all bolts off, downpipe, dust shield, and the thing still would not budge after 15 minutes of kicking it with the bottom of my foot I gave up this thing will not come loose.
    lame post I know but I'm pissed!
    17"enkei cdr 9 with falcon tires
    dropped to the ground
    k@n inhale and flowmaster exhale
    LXi User jlaccord89lxi's Avatar
    '01 Accord EX Coupe
    Nova Scotia, Canada
    try a rubber mallet because youre foot may damage it. The gasket can become siezed between the pan and the bottom of the engine block, so you could also try a pry bar to CAREFULLY separate them. If you dent either of the edges you will have some trouble with leaks in the future.
    May 2003
    88 Accord LX 88 Accord LXi
    Sounds like a good idea jlaccord. Listen to jlaccord, if you decide to try and pry it be very careful.
    LX User joebeets's Avatar
    88 Accord DX Auto AC
    Havre de Grace MD
    Based on my similar experience with a valve cover, if it's been on awhile, a varnish has formed and is acting like glue. Warm it up and it should come off.
    88 accord dx hatch
    santa rosa, ca
    screw it, I found a place that would do it for $115 if I get the gasket, oil, and other stuff needed. so this is what i'll do.
    Nov 2000
    Yeah, I paid about $140 a few months ago and got the whole thing done. Still felt weird to me since I have done everything myself on the car for 14 years. This particular Honda shop did such nice and neat work that it could make me lazy. I had them replace the P/S rack and both drive axles last week. Now I realize how much money I have saved over the years doing all the work myself. For some things, though, a lift and the proper tools makes all the difference.
    Jul 2003
    Here's a tip surely to work:
    Stick a metal pipe into the old oil pan( You dont have to go far, careful not to damage anything inside from the engine above!). Use that to pry the old one off. This will surely help you get that old rusted oil pan off. This works for me, and it took only a few tries.
    Made in Japan
    Feb 2003
    '86 Accord LX
    Kelowna, BC
    Damn, It took me like a few hours to pry mine off. It was not a fun day. Too bad I'm not old enough to drink beer.
    James
    '86 Accord LX 5spd > Bought for a hundred bucks.....Canadian. Leaks oil, has lots of rust, and is about 5 different shades of green.
    Mods: True ram intake, K&N, vacuum line removal conversion, 14" aluminum wheels, $20 cd player, $20 speakers, dual barrel air horn.
    Vinny's Avatar
    Aug 2003
    Here, not there
    I just use a big ass rubber mallet to "tap" around the edges til it breaks loose
    3geez Newbie
    Sep 2003
    1986 honda prelude
    Harrisburg Pa
    mine popped right off. the only problem i had was getting the rubber gasget off it was stuck like you wouldnt believe
    my oil pan was there for good. i had to use long try bar and some force.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    why do you guys need to take off the pan?? i havent?? should i??
    Travis
    Vinny's Avatar
    Aug 2003
    Here, not there
    Travis
    to get the all the oil out duhhhhhhhh
    Aug 2003
    87 Honda Accord LX-i auto & manual 88' Honda Accord LX auto
    Antioch, CA
    No way I was about to do it myself thanks for saving me the headache
    What did the 140 bucks include?
    Aug 2003
    Antioch, CA
    By the way why did you remove your oil pan?
    I need to change mine out because after stripping the bolt I tried to remove it by drilling out the washer to get somthing behind the bolt so that it would come out, but after removing it I noticed my little drill bit went onto pan creating a small channel wear oil leaks out.
    Idaho
    My oil pan came off easy......because my whole engine was out of my car for the five speed swap. Sure was nice sitting in a chair and not laying on my back under my car! You guys make it seem so hard when it's not.
    Aug 2003
    Antioch, CA
    Hey bite size how much did it end up costing you to do the 5 speed swap and now that its done is evertything running properly? Thanks
    Sep 2003
    1988 Honda Accord LX
    Ajax, Ontario
    just did the pan, came off no problem
  1. A stupid is as a stupid does
    By phrenology in forum Classic Honda Community Chat
    Last Post: 09-26-2010, 07:47 AM
  2. No, it can't be that stupid!
    By Sabz5150 in forum Classic Honda Community Chat
    Last Post: 03-25-2006, 09:10 AM
  3. Stupid car!
    By 88accordalltheway in forum Classic Honda Pics & Videos
    Last Post: 10-26-2005, 02:38 PM
  4. I'm stupid need help
    By #4bandit in forum General Engine Swaps
    Last Post: 08-29-2004, 09:44 AM
  5. Stupid stupid car!!
    By Hash_man_Se_i in forum Classic Honda Community Chat
    Last Post: 12-06-2003, 09:32 PM
